Hello,
I'm looking for receiver which has powered IR port which would allow me to control receiver behind closed doors. What I'm looking for is simple like I have now with Motorolla box where I have device like this (http://www.irblaster.info/motorola_rx.html) which plugs directly into IR port on Motorolla and has eye on the other side. I don't want complicated $150+ kits which I know I can use with existing equipment. I just purchased Yamaha RX-V673 and I assumed since it has remote IR port it will allow me to do what I did with Motorolla port but it appears to be a different kind of port which requires close to $200 in equipment which Motorolla box does for $20.
So which brands of receivers in same range as Yamaha RX-V673 do have this capability if you know?
G
G
