AVS › AVS Forum › Audio › DIY Speakers and Subs › Arauco Ply / HD 'Cabinet Grade' Ply
post #1 of 66
I've seen quite a few builds using this material.
Can anyone attest to the quality of this ply for speaker builds?
I've only used true 5' x 5' BB in the past for my builds. But the BB is always a little hard to get, and of course a tad more expensive.
Edited by smokarz - 10/20/12 at 10:01am
post #2 of 66
I use it when I can get it. Works better than about anything else outside of true Baltic or European Birch.
Arauco is very soft, but it is flat, relatively void-free, and works well. No complaints from me at all. Gonna buy another pile here shortly.
post #3 of 66
thanks mike, good to hear.
i am not sure it's Arauco, but I am referring to the $30 4x8 3/4 sheet from Home Depot. I hope we're talking about the same thing.
post #4 of 66
In my area at least, Home Depot doesn't carry Arauco ply, but Lowes does. I used it for a pair of THT LPs and a pair of TLAHs, and it worked quite well. Baltic Birch is a bit nicer, but the Arauco works well and is cheaper.
post #5 of 66
I think you may be looking at "cabinet grade" based on your $30 price (it just went to $36 here in RI). I have used this for various things (some shelves and a translam mini-monitor that is under construction) and it is very void free. HD here in RI does have what I assume is similar to "Arauco ply"...they call it "sandeply" or something and i think it is 9 layer in 3/4".
post #6 of 66
The cabinet grade ply was $35 here a few weeks ago. That's what I used in my builds and it worked fine. I noticed very few voids, and those voids were very small.
Nothing here was labeled Arauco. Didn't their plant burn down? The 9-layer ply was around $50 iirc.
Tim
post #7 of 66
If it's Arauco, it will say so. It is softwood pine plywood from farm raised Radiata pines that are pruned to minimize branches, and thus knotholes. I used it for my Table Tuba. The 1/2" thick that I used did warp, but easily pulled straight for nailing. My local Menards has it.
post #8 of 66
Smoke,
Why are you going ply vs mdf for your SEOS build. If you are looking for a flat black finish, I'm thinking mdf is the way to go.
My noob understanding is ply is desired for a stained finish and/or lighter weight. Since this is for mains, not a mondo sub, weight isn't that bad.
Just my 2 cents...
Java
post #9 of 66
That's exactly what I had in mind. I think they are now $32 in my area, still very cheap.
I had used them before for shelving in the basement and garage. They seem to look recent, but not sure they are 'speaker' grade.
post #10 of 66
Originally Posted by Java View Post
Smoke,
Just my 2 cents...
Java
I just hate cutting MDF, and they are easily dented while building or moving them around.
I agree, Erich's MDF flatbacks look very nice and better quality than the MDF at local hardware stores.
If I hadn't invested so much $$$$ in tools, I would definitely get the flat packs. I feel really guilty doing so while the tools are lying around unused.
I am looking at the HD ply, because I'll probably end up painting them. If I desire a stain finish, I would go with the BB as I did in the past.
post #11 of 66
I've seen Arauco once at Home Depot and keep asking for it. I've always been told they've never had it and can't order it.
Then I finally realized that they call it "sanded pine", and even though it has the Arauco name stamped all over it, Home Depot employees don't recognize the name.
Once I finally figured this out and asked about availability, I was told they only get a single order once a year in November. (?!?) Oh well, it's almost November.
I've used 3/8 and 5/8. No complaints with 5/8 but the 3/8 warped terribly and due to the narrow panels I was using it was very difficult to pull back into shape during building. If I use 3/8 again I won't cut it until I'm ready to glue everything together, and do it quickly. Other than that it's lovely stuff, very light, but soft. You can dent it with a fingernail.
If anyone knows of a more consistent supplier in southwestern Ontario, let me know.
post #12 of 66
This is 1/2 inch Arauco.
3/4 looks the same, just adds 2 plies to the center. I can't get it at Lowes out here, HD used to have it. Now I have to drive up to Compton's in Seattle to get it cheap.
post #13 of 66
I get mine from the local building supply. Haven't checked availability since half the Auraco factory burned down though. Pic is 3/4" sitting on 1/2". The 1/2" is factory edge - 3/4" ripped.. These are both over a year old.
post #14 of 66
Went to HD twice this week to look for their $30 'cabinet grade ply', but haven't seen them around.
Anyone know if they still stock them?
post #15 of 66
I was HD here about a week ago and they had the cabinet grade ply.. it's not $30-- I think it was $35 (maybe $39?). They also had "sand-e-ply" (I've forgotten the price) and some sort of oak ply for $50. I could see large voids in the edges of the oak ply.
Tim
post #16 of 66
I see the poplar ply, it was either $35 or $36.
I don't think it's the same stuff that I bought before.
It looks different.
post #17 of 66
Bought 3 sheets of 3/4" from the local HD (north Georgia) about 2 weeks ago for $34 per sheet. Display was marked "cabinet grade" but each sheet was labeled Arauco. Cut into about 60 pieces for a large wine rack & found only 1-2 small voids per sheet. I've also used it for several speaker builds & fill the (rare) void with wood glue.
post #18 of 66
Guess I'll have to go back in and ask for the cabinet grade ply.
post #19 of 66
I can, as will a few thousand builders of my cab designs.
Sandeply isn't Arauco. It is poor quality, as is Blondewood. Arauco is the only big box plywood I've found to be usable.
post #20 of 66
This is what I used:
post #21 of 66
Mr. Tim, I have run about 100 sheets of exactly what you show in your picture above thru my cnc machine this past year (in the summer of 2011, it was $25 a sheet but has steadily gone up). I have built speakers, large and small, murphy beds, display cabinets, kitchen cabinets, etc. and love the stuff.
post #22 of 66
I recently built a workbench and speaker stands with this stuff. It seems like good material for the price although I hadn't considered it for speaker builds. Good to know, my HD usually has it in stock.
post #23 of 66
Found a link for this product on the HD web site. They do call it Arauco ply online.
Unfortunately, all my local HD are Out of Stock.
http://www.homedepot.com/h_d1/N-5yc1v/R-202519005/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=cabinet+grade+ply&storeId=10051
post #24 of 66
Tim
Dont do it, had a void that ran through the entire sheet of one, didnt find it until I had cut into it. The BB i found looks as if two sheets are perfect, the other two are going back to be exchanged for two more that appear a little better on the edges. Overall I am very impressed with the wood quality tho.
Don't expect that to change for the better as their main plant in Chile burned down.
post #25 of 66
Damn, really? I just went through 2 sheets for random stuff I built of this stuff and it was virtually void free. frown.gif I'm getting ready to kick off a subwoofer build and was hoping to pick this stuff up vs. MDF since it's a bit easier to finish. I'll take a hard look at what's in stock, but I can always go back to MDF. Birch plywood is available at my local big box, but Baltic birch is no where to be found in my area. frown.gif
post #26 of 66
http://www.homedepot.ca/product/5-8-inch-sanded-pine-plywood-19-32-inchx4x8/967017
Same product (except for thickness), same picture even, but in Canada they call it sanded pine.
post #27 of 66
My local HD's cabinet grade ply is full of voids. The only ply they stock which appears to have a halfway decent cross section has paper thin veneer that's certain to peel.
post #28 of 66
Solution: Don't go to HD. Go to a real lumberyard. If you're looking for cabinet grade plywood find a local kitchen cabinet maker in the Yellow Pages, ask him where he gets his wood.
post #29 of 66
The sandeply from home depot looks good to me. The sales a associate told me it was void less. Can anyone confirm? Goes for about $45/sheet
post #30 of 66
Sandeply is sub-standard.
