I I have a pair of Opus2-AVS speakers that were used for display purposes only at the CES Audio show. These speakers were not available for general distribution in the United States. Included are two AvS speakers from the Opus2 AV system. They can be wall hung or possibly placed on stands. Price is $450 for the pair + $39 shipping.
Color is satin black, but as you can see, the grille covers the entire front. The grille has metal pegs (a great advantage over Wharfedale's traditional plastic pegs that break easily). Retail price for the two speakers is approximately $1,650.
See link for more details:
http://www.soundimport.com/opus2-avs.html
Spec
Type 3-way wall mount front AV speakers
Bass driver 170mm KEVLAR
Mid-Range 75mm Textile dome
Tweeter 25mm Textile dome
Nominal Impedance 6ohm (8ohm compatible)
Frequency Response +/- 3dB 45Hz - 43kHz
Recommended Amplifier Power 40 - 200w
SPL (1w@1m) 88dB
Dimensions (h x w x d)mm 500 x 230 x 140
Nett weight 9.0kg each
Edited by jcm2128 - 11/24/12 at 7:21pm
Spec
SPL (1w@1m) 88dB
