Originally Posted by Kirnak
Here's the Grayscale after calibrating the 5020/LPE with a borrowed iscan Duo video proccessor. No hit in lumen output to get this. 100 IRE green was not dropped, rather Blue and Red were bumped up. So, if anything a slight bump in lumen output. The bump in Gamma at the higher IREs and the drop in Gamma at the lower IREs was intentional. Also, I could have easily tightened this up, but I saw no need. I'll get better numbers when I get my next--and hopefully final--replacement PJ from Epson. Right now looking at around 1700 lumens in Normal and 1200 - 1300 in ECO.
Zombie, I have a filter in hand to loan to you for testing...
thanks for letting me checking it out. The results look good, have you run it through the full autocal yet?
When I was using a ceiling mount though with my other screens, I was able to simply pad up the lens between the lens and projector housing with some foam/rubber type material which was enough to keep things stable for the most part. A little experimenting and trial/error should get a stable lens though from my experience even though it is a PITA initially.
