Yes, I read it. He gives black level and brightness measurements, contrast numbers, etc. for his screen and setup. He says all three are better than last year's models, and much better than $10,000 projectors from not very long ago. He notes that ghosting is worst on the JVC, but that overall he prefers it because of the high native contrast. It seems very much in line with many of the conclusions we're seeing here. In other words, most people are going to be happy with any of these projectors, but your priorities will determine which is the best fit for you.
post #3181 of 4150
1/23/13 at 1:34pm
- Joseph Clark
- Trader Feedback: 0
- offline
- 9,579 Posts. Joined 3/2002
- Select All Posts By This User
No way am I trading out my 9' wide image for a 65" diagonal flat panel though! I am sure you will absolutely love going to a FP setup as the overall experience cant be beat IMO.
3d is just not what the JVCs are meant to do IMHO. If you want quality 3d AND a JVC for 2d, you need 2 separate projectors. Maybe this will change with next years models.
