Hi there from Germany,
I just registered to the forums but I read a lot here before registering now.
zombie: Those comparisons you do here and did in the other thread are very good and seem to reproduce the reality one can see with his own eyes very well IMO.
One question: Is the HW50 you now have a pre-production sample or a serial production one?
I've recently had the chance to review a HW50 in my room and did a direct comparison to a JVC X30. The HW50 unfortunately was still a pre-production sample. Concerning the noise/grain that will be emphasized by the RC: We found that the Noise-slider in the RC-function had nearly no influence on the noise, but the MPEG noise reduction in the expert menu did. For example with The Dark Knight we set MPEG Noise reduction to low and it did a good job to soften the noise again when the RC was on, but the effect of the RC was still visible.
Ekki from cine4home wrote nearly the same in his report.
Looking at the "mechanical sharpness" of both the projectors (that means definition of single pixels by looking very close, and impression of the overall sharpness when all sharpness settings were set to 0 on both projekctors) the JVC X30 was definitely better there.
With the RC on, but not too high (the default 20 seems already very high, I then set it to 10) and the MPEG noise reduction set to low, picture seemed a bit sharper then on the X30.
However the MPEG noise reduction didn't work with all movies, Apollo 13 for example has a very coarse grain, there I found no setting to reduce this grain that will be sharpened by the RC.
So maybe you take the MPEG noise reductioin into consideration as well with your tests.
What we also haven't tested is the influence of the normal sharpness setting in the picture menu and how it works together with the RC. We set the sharpness in the picture menu to 0.
