Yes, I think that's correct. I haven't yet read about someone using the new JVC RF system with the old projectors. The new systems will be sold beginning end of november I think, so no one had yet a chance to try this I think. It is possible to use the RF system with the older projectors but I can't imagine that this reduces the ghosting much.
post #991 of 4160
11/15/12 at 10:03am
be interesting to know if the new model epsons are the same in this regard
) so I used the shrink method where you leave the projector zoomed for 2.35:1 and 'shrink' the 16:9 menus, trailers (and whole films if you want) to a lower resolution so that the height fits on the 2.35:1 screen. I found it worked really well until I managed to find a used Isco II lens. I've since upgraded to a Lumagen Mini3D but it can do the same shrink if required. Not only that it can do the 125 point CMS with autocal if combined with Chromapure (or Calman) so you get a better CMS than the higher up JVC models (without the linearity issues either).
