AVS › AVS Forum › Audio › DIY Speakers and Subs › Sealed box for IXL-18
Sealed box for IXL-18 - Page 2
post #31 of 40
Resurrecting this thread again. Got my 2 IXL-18 Mk2 drives this week. Planning to put them in two 4cuft sealed sub enclosures from DIY sound group. Would two Dayton SA-1000 rack mount amps be enough to power each of them in a 2600 cuft room? Seems like the amp has a defeatable subsonic filter & bass boost which is perfect to boost low end in a sealed cab. Also looking at Crown XLS series amps to power these. The amps will be in the theater room therefore looking for amps that are quiet.
Edited by vinodk - 11/10/13 at 8:54am
post #32 of 40
What frequencies does the Dayton amp boost? If you are going sealed, I would think that using a HPF would be unnecessary. For the price of the Dayton amp you could purchase a new EP4000 or an iNuke3000dsp, either of which would likely be better.
post #33 of 40
I am looking for something quiet as the amps will be located in the theater room. I believe Dayton applies boost around 25hz. The subsonic filter is defeatable on Dayton so that works out well. Not sure how the SA1000 amp tested in bench tests.
post #34 of 40
There are lots of quite amps out there. I have personally owned both the Behringer EP4000 and the Behringer iNuke3000. The iNuke is a pretty quite amp, and with a fan mod, it becomes even more quieter. The EP4000 is pretty loud, but a fan mod will help significantly. If it were me, I would go with the iNuke3000dsp. That would offer up some nice power reserves, be pretty much silent, and also give you the ability to use its on-board dsp for boosting, assuming you build a sealed sub.
post #35 of 40
Thanks Marty. I think I might go with iNuke3000dsp & just do the fan mod if necessary.
post #36 of 40
Ready to pull the trigger on iNuke3000 amp to power two IXL18 MK2 subs in two 4cuft boxes. It outs out a little over 800 watts per channel at 4 ohms. Is this an RMS rating or peak rating. Just wanted to be sure as the IXL drivers are rated to take 800 watts RMS & wondering if I should step up to iNuke6000 but then again its not rated for 2 ohm operation & it will take one more fan to replace.
post #37 of 40
Are these IXL-18 mkii subs a duel or single voice coil design? Are you planning to wire them to present an amp load of 4 ohms, or 2 ohms? If it were me, and I had duel IXL-18 mkii subs, I would most definitely step up to the iNuke6000dsp, also assuming that you wire them for a 4 ohm load at the amp.
I am not certain that the iNuke3000dsp can push two of those IXL-18's to their maximum potential, although I have not modeled it, just going off what I have heard/read about the IXL.
What made you want the IXL-18 mkii over something like the UXL-18?
post #38 of 40
Hi Marty, these subs are single voice coil & present 4 ohm load. Went with IXL due to price. To my understanding the main difference between IXL & UXL is mainly the cone material & higher xmax. Other than that the basic voice coil/motor appear to be the same.
post #39 of 40
Will the IXL offer better performance than the Dayton HO18 or SI18? I looked at both the IXL-18 and the UXL-18 before deciding to purchase my HO18's, and if it were not for the price, I would have gone with the UXL-18. Sucks that my PC has a shot hard drive as I have been having to use my iPhone 5, which can't do winIsd, to my knowledge. I wonder how the IXL models compared to the cheaper Dayton and SI 18's.
post #40 of 40
They changed the design of IXL18 mk2 this year. Compared to previous model it has bigger 3" voice coil & a different motor design more akin to UXL18. I already have SI HT18-D4 therefore figured I try something different. My main use is for movies.
