AVS › AVS Forum › Audio › Receivers, Amps, and Processors › REW Measurements for Room Correction Systems (YPAO, ARC, Audyssey etc)
REW Measurements for Room Correction Systems (YPAO, ARC, Audyssey etc) - Page 6
post #151 of 159
It is a single speaker, no sub.
Could I ask for a return favour and get your Fuzzmeasure file for the XT32 measurement you posted above?
post #152 of 159
Sure. Do you have FuzzMeasure? The file is rather large (>200MB). I also could send you just the impulse responses. About 4MB each.
post #153 of 159
Yes, I have Fuzzmeasure. Whichever is easiest.
post #154 of 159
Here's a temporary link:
https://dl.dropbox.com/u/21936387/audio/stevedodds.fume3.zip
Please let me know when you have it.
post #155 of 159
Thanks Markus, the file works fine.
Was that measurement from one position with XT32, or multiple positions?
post #156 of 159
Single measurement at the listening position.
post #157 of 159
Interesting. Could I ask what speakers you were correcting?
I've just sold my Anthem after the benefits of ARC couldn't overcome the annoying glitches of actually using it, so maybe it is time to give Audyssey another try.
post #158 of 159
That was just a temporary setup with the speakers placed directly at the side walls. That's why there's such a hump around 100Hz. Anyway, it shows that XT32 is very effective in flattening the steady-state response.
post #159 of 159
Originally Posted by amt View Post
XT32 really seems like a winner. I wonder if anyone could develop a version of XT32 in which the user could customize the frequency range that XT32 applies its filters, for those who would prefer that above a certain frequency nothing gets changed.
+1
