Hello everyone,
I'm in the planning stage right now for my HT. I'm finishing the basement, so I have a fresh open space to work with, with 9' ceilings. After working with the family on the overall design of the basement, I came to the final inner dimensions of 12' x 17.' I would like bigger, but this is absolutely the best I can do. Gotta meet the needs of all family members.
The outer dimensions are 13' x 18' because, after extensive research, I've decided to build a room within a room. I want the best possible sound proofing, and I've read that the best design is to completely decouple HT room.
Here's the plan so far. I will use resilient channel for the ceiling, 5/8" drywall and possibly a second layer of 1/2" drywall with green glue. There will be 4 recessed ceiling lights, where I plan on building backer boxes. I will be covering all pipes and HVAC duct with a sound dampening material, as well as a muffler for the HVAC.
There are a couple of questions that I have that are gnawing at me as I try to gather the numerous facts and tips from the web.
1. I've read that it's best to avoid in-wall speakers when soundproofing a room. I wouldn't mind that, except that I would not have space in back of my last row of seating. But I don't think in-wall would be a problem for the rear speakers in my case if I build a backer box, since the wall will be decoupled. Any thoughts? Can in-wall speakers provide robust sound for a HT?
2. I can't find any good recommendations for how much space between both walls is recommended. Just "as much as possible." I realize that the more the better, but since the room size is constrained, I don't want to space them more than 4 inches apart. Any suggestions as to what the minimum spacing might be without it being a pointless endeavor?
My first step in this process is to study everything I can about sound proofing. Once I'm comfortable with the master plan, I'll start consolidating all of my info on screens, projectors and receivers. This site is such a great source!
Thanks in advance!
Thanks in advance!
