AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › convert file from vro to mpg??????
post #1 of 12
trying to convert the vro file that I burned from the panny E80 onto a dvd-ram to edit the home movie.
having a BIG hassle trying to find a program to do this.
have purchased aura4you audio video convertor it will only convert 10 minutes of the video,, also tried freemake , still no go.
what can you suggest of a convertor that will work??
i do not want to purchase a $100 program like tmpeng.
HELP!!!!!!!!!
please?
post #2 of 12
HELP!!!!!!!!!
please?
Your pc, of course, must be RAM compatible. You can use the trial version of VideoRedo to edit, create a dvd, and burn to -R.
http://www.videoredo.com/en/Download.htm
Umm...you could edit the program on the E80, unless, you want a more refined dvd menu for the final product.
post #3 of 12
HELP!!!!!!!!!
please?
This forum is really for discussion of stand-alone DVD recorders, modern replacements for the old VCR.
You're talking computer programs and such, and that's really a different subject entirely.
What I'd suggest is that you go to the website www.videohelp.com and check out their forums. If you can't find anything already posted that'll help you, you could join and post a message. Those guys are REAL helpful with finding the right program to do this or that, and they have a large membership so there's usually someone who can help you.
There's also a lot of freeware out there they provide links to. Some of it may do exactly what you need.
post #4 of 12
have it edited the way I want it.
what i NEED us to add music, and that is the problem, none of those programs will read a vro program
will the program you suggest convert the whole 58 minutes? or is it just a trial that does part?
Edited by muffyn - 10/22/12 at 11:50pm
post #5 of 12
I just needed a push to get some answers, (there have been some threads on this board that does mention conversion)
anyway I have spent literally days looking for a program that works!
searching , just any straw of threads on the internet, that have some kind of answer.
I am getting tired of downloading programs that say they will work & then don't.
(& I thought I'd start IN this forum since the .vro was made from my hdd recorder <<panasonic e80h>> , I figured some of you would know what I was talking about. the file dubbed from the hdd onto the dvd-ram is only in .vro, my computer will not read a dubbed dvd-r only the dvd-ram)
Edited by muffyn - 10/23/12 at 12:07am
post #6 of 12
As far as I can recall, VideoRedo doesn't allow altering the soundtrack when editing.
I have an older version of a program called TMPG DVD Author which allows you to replace the soundtrack when creating either a DVD Video or Divx file. The program accepts DVD-RAM discs and vro format recordings for editing. Their site features an updated editing software called ''Video Mastering Works'', and the video on the site features the same capability. But I don't know how extensive your audio additions are/need to be. If you can create a separate audio file that is the exact length of the video you want to convert, then you'd be able to get what you want done out of this program.
http://tmpgenc.pegasys-inc.com/en/product/tvmw5.html
The free trial will leave a watermark on the completed file (at the beginning and the end).
post #7 of 12
@muffyn
I don't see how you are going to find anything freeware that will do what you want -- especially when it comes to replacing or layering the audio stream. The programs I've seen or used in the past that work on RAM based .vro files all cost $$. There is a possibility for you. .vro files are just MPEG-2 files. If you start with a fully erased RAM disk and record onto it a single title, I have in the past (with Panasonic E85) just renamed the extension from .vro to .mpg and had it successfully opened by an editing program. If the RAM disk is not fully erased you run the risk of video segments being out of order since RAM's are natively Random Access Memory/Media.
post #8 of 12
I only use a computer to recover unfinalized DVDs that will not finalize, so my question might seem inexperienced:
Why not use a DVD-R instead of a DVD-RAM to get the video content off the E80? Wouldn't the result be a mpg and not vro?
post #9 of 12
I guess the simple answer is that RAM's are reusable whereas DVD-R are not. I used RAM's with my E85 because, like the E80, it had no DVD-RW capability. Otherwise I would have used DVD-RW and worked with DVD-Video formatted disks -- much more straight forward.
post #10 of 12
my computer will not even recognize a burned dvd-r from the panasonic, so can't get any of those files to work with.
but it wil read the dvd-ram.
so, I dunno.....
post #11 of 12
so, I dunno.....
This has to be asked..are you sure those dvd-r discs were finalized? Just checking.
post #12 of 12
lol I see you guys ask this a lot.
yup they are finalized, I have 3 other dvd players (even a blue ray one) & the discs play just fine on them/
  Back to Forum: DVD Recorders (Standard Def)
