I downloaded Window 8 a few nights ago and installed in on one of my machines. My first thought was that it is going to end up being mentioned along with ME and Vista.
That said, I now have a programs menu, so at least that part is getting better.
Having to go to the bottom left corner and right click to get systems programs to appear on a menu seems silly to me. How much trouble would it have been to just give people the option of a start menu or not? I know 8 is geared towards tablets and touch screen machines, but the vast majority of machine out there are just regular old computers.
I did a clean install from XP. I decided to go ahead and try to install all of my old programs to see which ones work. Surprisingly, most of them do. If I decide to use it, I will have to upgrade my NERO program. For some reason, NERO will not recognize my DVD burner. I have since installed a Blu-Ray burner. When I put the 8 backup back on, I will check it one more time (NERO). If it still doesn't work, I will uninstall it.
I am not too keen on the big blocky (sp?) Metro look. I am sure that if Microsoft would have just TOLD people that all they would have to do is click the block for their desktop, it would have gotten a little better reception.
Office XP runs fine on 8. At least it does on my machine. I also have three old DOS programs that work as they always did. In fact, I have installed 34 programs that I had on XP and all of them seem to be working except for NERO.
It starts up fast, but then of course it doesn't completely shut down unless you tell it to. XP and 7 start up fast as well if you just put them in standby mode.
I don't think Windows 8 would be a cost effective upgrade for businesses running Windows 7. I don't see anything that would make me want to upgrade from Windows 7 unless I had a lot of touch screen machines. I would definitely not want to try and run a touch screen machine as a desktop business computer day in and day out. That would get old really fast. The mouse is more effective in doing what people need to do than reaching up and tapping a screen a few hundred times a day.
If you can get 8 for the upgrade price of $14.95 and are curious about it, you should go for it. I checked it out for a couple of days and then put my XP back on. I will get back to 8 in a week or so to check NERO and my BR device.
Edited by Country_Boy - 12/2/12 at 11:32pm
