AVS › AVS Forum › News Forum › Latest Industry News › TruAudio Announces The Trunami: Retrofittable In-Wall Subwoofer
post #1 of 3
TruAudio announces an all new, retrofittable in-wall sub called the Trunami. It comprises of a High Excursion Spider Suspension (HESS) designed 8" woofer, two 6.5" Bass Augmenting Drivers for deeper bass. It can be mount between 16" stud in standard thickness wall. It comes complete with MDF back box - retrofittable. Frameless, magnetic Ghost-like cloth grill for easy install and minimal footprint.
Press release:
"Designing the Trunami in-wall subwoofer was a labor of love. And that love began by choosing a TruAudio 8" woofer," states Kary Wawrzyniak, Vice President of Technology.
The Trunami's 8" woofer utilizes a linear High-Excursion-Spider-Suspension (HESS) design - specifically matched to its enclosure as well as the amp power level and frequency. Its Aramid fiber spider is the optimized shape for deep bass, linearity and break-up mode control at high drive levels. The woofer also has a large, high-energy ceramic magnet that achieves a higher BL product or "horsepower" for the Trunami.
The woofer magnet circuit was designed using Finite Element Analysis (FEA) to optimize the woofer's motor efficiency making for a unique subwoofer driver with high sensitivity, long excursion, producing deep bass in a small enclosure with low distortion.
Next, we added two 6.5" Bass Augmenting Drivers (BAD) to enhance the bass while keeping the dimensions of the Trunami cabinet to a minimum. The BAD's allowed us to design a very small enclosure while adding a radiating area equal to that of a 10" woofer.
The BAD's also augment the lowest range of the Trunami's 8" woofer. Tuned to vibrate in response to the bass energy coming from the woofer, the BAD's deepen the range several steps lower than the lowest pitches that the woofer can reproduce. They extend the Trunami bass a full -3db@37Hz when mounted mid wall near the floor. This gives the Trunami the aural perception of bass notes roughly half an octave lower than it would otherwise be able to reproduce.
All the Trunami drivers use a high tech, high temperature adhesive to bond the cone, spider and voice coil at a single region called "three point bonding". This assures high power handling with mechanical durability. The Trunami cabinet has also been internally braced for vibration free performance.
The use of multiple subs to prevent areas of bass null regions in a room of very low bass is fast becoming the norm in installations. In keeping with that trend, the Trunami has been designed to work as a single unit or in 2 or 4-unit configurations to minimize waves and phase cancellations in larger rooms.
Finally, we used a state-of-the-art CAD system in designing the Trunami so we could squeeze all this stellar bass performance into the smallest possible enclosure. The Trunami is small enough to mount between a 16" stud in a standard thickness wall. Coming complete with its own MDF back box, the Trunami is retrofittable. The Trunami also features a frameless, magnetic cloth grill that is both easy to install and minimizes the on-wall footprint.
Hopefully it will perform as well as it sounds.
post #2 of 3
I wonder if Lavasubs will eventually get a version of this
post #3 of 3
You mean as good as the marketing material sounds?
There's a lot of technical babble and very little data - which for a sub boils down to what SPL at what freq with what distortion.
  Back to Forum: Latest Industry News
