AVS › AVS Forum › Audio › 2 Channel Audio › Real Book Shelf set up
post #1 of 3
I am currently configuring a system the will reside in a bedside bookshelf. I will be streaming Pandora from an iPad. I would also like Fm capability. I will not be taxed power wise, 10-15 watts would probably be overkill. Any ideas on receivers, as far as speakers been looking at paradigm atoms, nht zero 2.0, psb alphas really have not made up my mind on those either. Any suggestions on equipment or implementation would be greatly appreciated. Thanks:)
post #2 of 3
At the budget end, there's a Sherwood 4105 receiver and an Airport Express. $200 and change.
post #3 of 3
fwiw, another suggestion on a good budget reciever look at the onkyo tx-8050 $219 at accessories4less. as for speakers imo i would look at something that is front ported or acoustic suspension design (no ports) if you are going to place them in a bookshelf. the nht super zero's are a.s.d but you might need a sub as they dont go that low in the bass dept.
