Hi ALL,
I have an HTPC in my set up and I use an X10 appliance module to turn it on and off. I also have an IR 543 that can accept an IR command and translate it to an X10 command. This way I can have my Harmony One remote issue an IR command to turn on or off the HTPC. But my IR543 just crapped out and I now find that they are discontinued. Is there any other device out there that can accept an IR command and then send out an X10 command.
An alternative would be a wireless switch but the only ones I found use RF instead of IR.
Any suggestions would be welcomed!
Gerry
Gerry
