Originally Posted by rwestley
As the owner of a JVC RS45 and the W1070 I can report that the 1070 is great at this price. I have a bat cave and with a little tweaking (calibration) the picture will be better than nearly any movie theatre. The blacks will not rival the JVC but the 1070 has great color, exceptional brightness and good shadow detail. It is also wonderful for 3d use. (3D was the reason I purchased it because of the ghosting on the JVC.) To my surprise it surpasses anything I expected for it and I will probably use it for most casual viewing including sports and other sources. Since I have a dark room I am using the SmartEco mode and I have turned brilliant color off. I am also using the film setting with gamma set at 2.4. I calibrated using Chromapure with my DVDO-ISCAN DUO and the results were amazing. Most of you will not have this option but the great news is that this projector has the best color I have seen right out of the box. With a little tweaking one will be able to achieve excellent results as long as dark blacks are not the most important thing for you. The other nice thing is that because it is so bright one can use it in a room with some ambient light if that is necessary. I have owned many projectors in the past and I have never seen anything at this price point that is as good.
Could you please post your settings after calibration and the screen type you use? Even though this may not be a totally accurate way to customize one's picture my experience is that it puts the receiving new owner in close proximity to the right settings.
Edited by JackB - 1/17/13 at 7:26pm
