Originally Posted by smokarz
With more recent user reports, I am having some doubts on the W1070. Light leakage, noise, not that much better than existing options.
The thing that attract me about the W1070 is its price, DLP, small offset and lensfhit.
Is this the best DLP option for this price range for 2D ONLY? Others I look at have too much offset (12"+ offset) which just doesn't work with my <7ft ceiling.
I made my review previously on this thread as objective as possible. I don't have an issue with the noise of the projector at all. As I mentioned, the light leakage is there and noticeable on credits-dark scenes, but 99.5% of the time it is a non-issue for and that is coming from OCD person. I mentioned some DIY potential fixes for light leakage if it is a problem. I simply placed a CD sleeve about 4 inches away from the exhaust where the light leakage is happening for a temporary fix. The only other light leakage is a slight leakage above the PJ... like a halo from the lens... I think if you were to get some foam and cut it in a circle to put around the lens this would fill the gap around the lens enough to block the light leak. (see pics) These cons are outweighed by the long list of pros this projector provides.
Light leakage from the exhaust and my temp fix CD Sleeve
Slight halo light leaking on ceiling - not as noticeable as exhaust.
At this price point (ESPECIALLY at the $899 VA has it for right now) there is nothing that comes close to this projector. As others have mentioned, image quality is on par with the $3000+ projectors out there. If you can get this to work with projector placement in your room and live with the light leakage, in my opinion you can't get much better than this without spending $3000+.
Edited by scottyroo - 1/21/13 at 12:00pm
) , but at the same distance.
