wont that make the image then uneven and create keystone problems? I thought the idea was to have the projector as straight on parallel as possible to the screen.
Still looking for a suggestion to my problem below if anyone can help, please...
Originally Posted by Thunder_God_Thor
Im having a problem getting the projector centred to the screen after ceiling mounting it. I mounted it in the distance range recommended by many calculators online including BenQ's and others. But the image just wont match up horizontally regardless of how much I zoom in or out... what gives? This is my first projector so I may have mounted it incorrectly but as I understand it the centre of the lens of needs to be exactly at the centre of the screen horizontally, yes? So for example I have a 92" 16:9 screen which is basically 80" wide. So if I mount the projector where the centre of the lens is at 40" horizontally lined up with the screen I should have a perfectly centred image horizontally, yes?
Issue is Im out by a lot at the moment horizontally (like 6-7") and I dont think I mounted it that incorrectly... Perhaps its a setting in the PJ or something? I have it at auto aspect ratio.
When I move the projector lens about 6" left of the centre of the screen the image then seems to be correctly displaying at-least horizontally.... does that seem right? I thought the idea was to have the centre of the lens exactly centre with the screen to get the image correct horizontally...
Any help is appreciated...
