Easy way to center your projector lens on ceiling relative to the screen:
1. Determine desired projection distance of your lens from screen using projector calculator.
2. Locate approximate mounting point on ceiling using projection distance measured from top center of your screen. You can use sidewall measurements to get an approximate screen center offset at the projection distance and mark on ceiling as the projection/lens point using pencil or tape. This is an approximate lens location since sidewalls may not be perpendicular to the screen wall.
3. Now use a tape measure and measure from top left corner of screen to marked projection point. Record this distance, while using the extended tape as a string radius to generate a circular arc while holding a pencil to scribe an arc of about 4 inches around the projection point.
4. Now place the tape at top right corner of screen and scribe another arc using the distance recorded in step 3. Where the arcs intersect is a point perpendicular to the screen and at the screen midway point. Just make sure that the arc intersection point is inside the lens focus distance for the projector.
5. If the projector lens is offset from the ceiling mount base, then offset the ceiling mount base by that offset distance to get the projector lens at the intersection of the two arcs.
Good luck!
Good luck!
Not sure how to fix that funky keystoning Im getting. I guess Im just an inept PJ/Screen installer.
