SAINSONIC SYNC FIX!
For all those who are experiencing syncing issues with the Sainsonic glasses, I have found a fix! I found an old thread here on avs that discussed the same problem. Basically it was saying that light sensor is too sensitive. They put a tinted plastic film over the sensor and taped it on and it worked.
I couldn't find any tint lying around so I used the red filter that comes with my old Avia calibration disc. I figured that it would filter out every color but red, which would be perfect for the red 3d sync flash. I cut out little pieces and taped it on the sensor. Works perfectly! There were several scenes on Despicable Me with bright flashing lights that would knock the glasses out of sync every time. Now it plays without any issues.
