Originally Posted by
accordex
I have tried all kinds of 3d so far .... no glasses... don't want to get into that right now except BUY FROM AMAZON NOT EBAY....
Anyways, from what I have tested so far here is the deal.
Playing a 1080p sbs mkv sample via windows media player,xbmc ect... will not work until you either set your pc output to 1080i or turn your receivers video convert on then simply, again set it to 1080i ,in which case it's a simple remote click, to allow sbs without having to change your pc settings.
Over under will work but the receiver(my pioneer 1021) does not have fps options so you have to put your htpc into 1080p 24hz mode...for some reason in this mode playing an ou mkv, the pj will actually allow you to hit the 3d button and select either top/bottom AND frame packing and either one seems to be putting out a 3d image...
Keep in mind I do not have glasses. Yet...
Now, using power DVD ultra and im sure other software, you simply leave your htpc, on 1080p 60hz , play the video, be it sbs or over under, and click the 3d button and the pj will blank out, find source come back on with info of 1080p 24hz 3D on using frame packing...
That's my input so far not having glasses... hope it helps...
I do have a question for those of you with glasses tho : )
When I play a 3d movie via media player it looks nice and bright and colorful... as soon as I hit the 3d button and select the mode it begins to flash the picture producing a rainbow flash for a few seconds and finaly settles producing a 3d pic...leaving the colors dull and brightness low... is this normal and will look better with the glasses?
Got mine from va and seem to be the only one with 1.03 from them...everyone else got 1.04 ...not sure if that's the issue... those of you that have glasses, could you leave them off and play a video and turn on 3d and let me know if you see the weird rainbow flashing till it sets into 3d? I would appreciate it...
