Originally Posted by Ezzelin
Does anyone else have any image noise on their W1070? In dark areas I can see what looks like film grain noise. The noise reduction in the menu doesn't seem to change it. I'm using good quality HDMI cables, and I've tried them on both HDMI1 and HDMI2. Thankfully, it isn't visible at seating distance, but it bugs me that it's there in case I ever want to project bigger. It doesn't show in the parts of the screen that are taken up by the menu when I bring that up. I've taken a video of it:
http://youtu.be/Dt23cx77Osw
Also, I got my 3DTV Corp glasses the other day and tried them out last night. They worked very well. I've already ordered two more. I had no sync issues all night and the red was filtered out. Here's the link:
http://www.ebay.com/itm/DLP-LINK-Glasses-2-Mitsubishi-Samsung-DLP-TV-DLP-Link-Projectors-/150882711282
Coraline and Street Fighter IV both looked wonderful in stereo 3D. The motion in 1080p24 3D was very smooth in Coraline, so I won't be missing CFI. I'm really loving the 144Hz. 720p in SF4 didn't look blurry at all, and I noticed no input lag. Still wish I could have 1080p 3D at 60Hz, but I'm sure it will come someday to a projector. I'll just have to use my BenQ XL2420TX for now when I want that.
[/quote
In one of the reviews it was suggested that there was some nose in some of the modes. The suggestion was to turn Brilliant Color off, use Cinema Made and Smart Eco to get the best possible picture without noise.
Regarding the 3D corp. glasses. Be sure you get the non-rechargeable ones. The rechargeable version will not work with the 1070. I have tried several brands including Sansonic OKBA, and True-Depth. both work fine. The True-Depth block the red flash a little better and are more comfortable they are also rechargeable and cost about the same as the 3DTV glasses. . The Sansonic also work and are a good buy for about $25. each. The Okba's also work fine for about $25 each even though they are not listed at 144kz. I would suggest that if one is interested in buying multiple pairs of glasses that they get one or two pairs of the new versions of the True Depth. (Be sure to get them from their own website since Amazon may not have the latest version). If you need more pairs for guests and children the Sansonic and Okba will work fine.
[/quoteIn one of the reviews it was suggested that there was some nose in some of the modes. The suggestion was to turn Brilliant Color off, use Cinema Made and Smart Eco to get the best possible picture without noise.
Edited by rwestley - 2/13/13 at 4:46am
