AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$
BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 11
post #301 of 4967
Originally Posted by Yusuf.0088 View Post
Only 634 euros on CU.
http://www.computeruniverse.net/products/90491948/benq-w1070-3d.asp
Shows as €754,- ?
post #302 of 4967
It shows a trapezoid image, so there is a keystone effect. The 1070 has automated keystone correction using a sensor in the projector, so I presume the 1080ST does the same.
post #303 of 4967
Originally Posted by donaldk View Post
Shows as €754,- ?
Change your country at the top of the page
post #304 of 4967
Originally Posted by nthydro View Post
Judging from that image of the W1080ST, it's nowhere close to center of the screen. I dont know if its keystone or offset?
Like most low cost projectors this one is meant to be hung from the ceiling or set on a coffee table (like in the photo). The small lens shift will allow you to move the projector a little bit higher or a little bit lower and still hit the same screen, but it certainly will not allow you to mount it on a shelf aimed at the middle of the screen without physically tipping it and activating keystone correction to adjust for the resulting trapezoidal image. As I think has been stated before, this pretty much excludes this projector from being used with a high gain screen which requires the projector to be close to eye level for maximum brightness.
post #305 of 4967
@nthydro when I said 'from the centre of the image' it means, that is how the lens shift is measured. In other words, the % (up or down) is from the horizontal centre line of the projected image. The user manual declares a total 20% lens shift (10% up from the centre or 10% down) Yet someone here mentioned 5%.
So I guess we have to wait for a 'hands on' user evaluation, once someone gets their w1070 setup & running.
post #306 of 4967
This is the spec:
Vertical 110%-130%±5%
note the ±5%
This means that in the "best" scenario, the image will be 5% above the center of the lens at "minimum image shift" but it could be as high as 15%. Same goes the other way, you could be able to shift the image by as much as 35%, or as little as 25%. On a 120" image, 5% = 7.5cm (this is in the benq manual)
post #307 of 4967
Shows as €754,- ?
Still 633.61€
post #308 of 4967
Kraine:
"It's a very small vertical lens-shift and it's working only in a positive way + 30 cm to the top from the center of the optical engine."
http://www.avsforum.com/t/1435626/benq-w1070-dlp-full-hd-3d-ready-with-lens-shift-for-1000#post_22533849
He tested W1070 on 100" diagonal screen. So, something wrong...
Edited by Yusuf.0088 - 11/30/12 at 11:21am
post #309 of 4967
Just got off the phone with NCIX, they are shipping to the US and it should go out today or tomorrow and arrive by next week. Cant wait, been putting off getting a screen to see how it looks first ( although I will have to come up with something for testing since my walls are very dark.
post #310 of 4967
I am following Kraine in his website, and here are some notes that I concluded:
- Kraine said W1070 3D is in level with HD33 and Acer H9500bd, which is means in same level of BQ W7000. He gave W1070 low score because he said pop out was not as good as Sony HW50ES. I hope BQ glasses were the reason for his comments.
- Projectors being shipped are firmware 1.2, while he tested firmware 0.8, Hope we see good improvement.
Edited by mishari84 - 11/30/12 at 6:22pm
post #311 of 4967
They may ship yours fast but they are damn slow to ship mine! Still waiting and they apparently began shipping them on Wednesday..
post #312 of 4967
Oh I knew what you meant (I think lol), but I think we're both talking about different projectors? The W1070 you are alluding to has lens shift and the short throw version W1080ST does not have lens shift. I was hoping since the W1080ST has no lens shift that it would at least have a higher offset so it could be ceiling mounted closer to the top of the screen, rather than near the middle where it might block the view.
post #313 of 4967
Originally Posted by mart242 View Post
This is the spec:
note the ±5%
So that means you can only move a 120" image 7.5cm up? That's only like 2 or 3 inches? That's very small :-/
post #314 of 4967
This is the spec:
note the ±5%
If this is true, ceiling mounting could require hanging the projector very low.
As an example, a 120" diagonal screen has a height of 150cm. Let's assume a 20cm drop from the ceiling to the top of the screen (to account for the screen housing). Ignoring the ±5% error tolerance, at max projector shift of 130%, the center of the projected image would be 45cm below the lens. That means you'd have to hang the projector 50cm below the ceiling, in order to put the center of the projected image at 20+(150/2) cm below the ceiling, to match the screen.
A 50cm projector hang is almost 1' 8". Not pretty.
Real owners: please confirm this!
post #315 of 4967
No, the range is 110%-130%±5%, so around 20%. This means ~30cm or so
post #316 of 4967
The 5% that I've mentioned (ie: 7.5cm for a 120" screen) is the OFFSET for the BOTTOM of the image from the center of the lens. This is as per the BenQ user manual.
post #317 of 4967
Kraine's testing of the lens shift appears to differ from the user manual, and there is a German forum where I read (translated google chrome) a guy has recently bought the w1070 and he got 5cm lens shift with a 1.9mtr wide image..........
hello people, now I can only tell my subjective feeling .. I find the picture just awesome, my wife thought it was really hot so the picture,,, rainbow effect, I can not see, volume in eco mode for me very disturbing, the only thing that disappointed me a bit is the lens shift .. 5 cm high and 5cm down ... pictureWidth the moment approximately 1.90 m ... but since I have space, it's not so tragic. BENQ w1070 was the right decision even if you get more money for even longer, but does not necessarily have :-) Greetings Salewo
after my wife found it visually beautiful, I saw him once connected and times projected from neurgierde beige on my glattverputzte cellar wall. canvasneeds to be assembled. 've now grad times sky hd watched football and now ne round played fifa ... top it all, the feeling says ..
Page 10.... http://www.hifi-forum.de/viewthread-94-12408-10.html
By the way guy's, I've had the W1000+ for 2 years now (just changed the lamp) and it's pop sharpness/brightness used on eco mode, I am still very happy with it, 1080p is awesome, runs quiet and I don't see RBE.
post #318 of 4967
Hmm.. 1.9m wide means that he's got a 1m high screen. 5% of that is 5cm so he's only getting a total of 10cm travel (10%). Definitely not much. I hope that the pj mount I bought from monoprice will suffice since it's really short.
post #319 of 4967
I was complaining about the same thing. I checked the calculator on BenQ's website and it said I had to hang the projector 18", which is going to look ugly with my 8 foot ceiling. If you factor in the height of the projector, its going to be hanging about 6 foot above the ground. Which means any tall people are going to be running into it LOL. No way my gf would approve of that rolleyes.gif
post #320 of 4967
After staring at the W1070 manual, I've concluded that their description of the lens shift feature is terrible. smile.gif
The truth appears to be this: when ceiling mounting, the top of the projected image is always below the lens. How much below depends on the lens shift: the vertical distance from the lens to the top of the image can be between 5% and 15% of the total image height.
In my example above for a 120" diag screen, the image height is 150cm, therefore the vertical distance from the lens to the top of the projected image can be anywhere from 7.5cm to 22.5cm.
That's much better!
post #321 of 4967
That's much better!
Yeah, the manual sucks for the lens shift! It took me a few shots to understand and even then... my understanding matches yours (except that I believe that the shift goes to a minimum of 25% height, ie the 30% - 5%)
post #322 of 4967
So we will probably see the W1070+ early next year with better offset/lens shift which is typical of Benq. You would think they would get it right before they knock em out the factory lol smile.gif
post #323 of 4967
Can you elaborate?
post #324 of 4967
The figure on Page 20 is the key. The top diagram shows that "100%" refers to half the screen height. Then, the vertical offset from the lens to the edge of the projected image is shown to be 10%-30%. But remember 100% refers to half the screen height, which is incredibly confusing. If you instead refer to the full screen height, then the offset becomes 5%-15% of the full screen height.
post #325 of 4967
Can you elaborate?
I can't because if you read my post, that comment is taken from a German hifi forum.
I did read somewhere ( I will need to check) that the W1070 had more than one fan, but I will need to clarify this, so don't hold me on this one.
post #326 of 4967
It's not clear which parts of your post are your own comments, and which are quoted. Try editing it to use the forum's quote feature (the " toolbar symbol) around the quoted parts.
Edited by Brian Miller - 11/30/12 at 3:46pm
post #327 of 4967
Very confusing but I think I get it now....
Regardless, I think anyone who is planning to ceiling mount is going to need a long mount frown.gif
post #328 of 4967
I don't think so, but it depends on how low you want your screen to be. Here is an example. Let's assume use of a short 6" mount. The W1070 itself adds almost 2" (distance between mounting surface and lens center). For a 120" diag screen, that means the image will be between 11" and 17" from the ceiling (approx). That's pretty low. I think it would fit most installations.
post #329 of 4967
Next batch from Netlink started shipping.
post #330 of 4967
Originally Posted by mishari84 View Post
I am following Kraine in his website, and here is some notes that I concluded:
- Projectors being shipped are firmware 1.2, while he tested firmware 0.8, Hope we see good improvement in our projectors.
I ordered mine last late last night, and I just received shipping info, that was quick. I also updated the my earlier comment, Kraine mentioned very good informations.
I sold my W7000, and I am more excited to get this due to newer technology and cute size and weight.
