AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$
BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 12
post #331 of 4908
Originally Posted by mishari84 View Post
I sold my W7000, and I am more excited to get this due to newer technology and cute size and weight.
Very excited to hear your comparison of the w1070 and w7000. I'm trying to decide between the two.
post #332 of 4908
Got my shipping info tonight as well, only a couple hours ago. That's fine, cause I went out drinking with some co-workers and totally forgot about it!
post #333 of 4908
I don't see how the W1070 could be better, except for form factor!
post #334 of 4908
dark chip 3 instead of 2, 6x color wheel instead of 4x, brighter in both 2D and 3D, large improvement in native contrast. I DO see how it could be better! almost sounds too good to be true so I'm eagerly awaiting reviews.
post #335 of 4908
Originally Posted by Brian Miller View Post
I don't think so, but it depends on how low you want your screen to be. Here is an example. Let's assume use of a short 6" mount. The W1070 itself adds almost 2" (distance between mounting surface and lens center). For a 120" diag screen, that means the image will be between 11" and 17" from the ceiling (approx). That's pretty low. I think it would fit most installations.
Here's my scenario using the BenQ calculator for the W1080ST:
screen size: 120" screen
ceiling height: 8'
distance from projector to screen: 6'
distance from ceiling to screen top: 1' 6" (screen mounted 1/3 eye level)
distance from ceiling to projector: 1' 5"
So according to the calculator I would need a 1' 5" (17") projector mount to achieve that setup. Add in the projector height (maybe 5"?) and it's like a 22" drop from the ceiling, which for a room with 8' ceiling, it's kinda in your face lol.
post #336 of 4908
The only obvious advantage from what we know is that W7000 has dynamic iris, which I turned off all the time..
post #337 of 4908
eek.gif And they are still selling the W7000 for 2x as much?
post #338 of 4908
ceiling height: 8'
I agree, that is kinda in your face! The numbers for the W1080ST appear to be worse than the W1070 (I only considered the W1070 in my earlier post). Any chance the W1070 could fit your room?
post #339 of 4908
Yeah I'm definitely considering the W1070 as well but problem is I want to use the Xbox Kinect so I might need a short throw projector to not be in the way of the projection. I used the calculator to see if the W1070 would be any better and it was 2" higher than the W1080ST, which is an improvement but still kinda hanging low (W1070 = 15". W1080ST = 17"). Looks like I might have to tilt the projector and use keystone, cuz no way my gf would let me hang a projector that low in the living room biggrin.gif
Thanks for your help.
post #340 of 4908
I know, right? That's why it seems to good to be true. All the "problems" of the w7000 (loud iris, poor native contrast, rainbows) seem to be improved on the w1070 and the price cut in half to boot. It looks like they just cut out the stuff everyone doesnt use (frame interpolation, detail enhancement, the iris, etc) but kept all the really good stuff and improved upon it. Is this possible? I hope so!
Edited by tallnick - 11/30/12 at 11:06pm
post #341 of 4908
I'm sorry in advance..but i'm a noob to all this. I just want to get this projector right now...but i'm confused when I used the calculator. I have a room that has 8ft ceilings. I want to mount the projector 13ft from the screen. I want the screen to be 100", and centered on the wall (2ft from top, 2ft from bottom). The screen is about 4ft high. All I want to know is how low I will need to mount my projector from the ceiling. Also..if it does need to go on a shelf about 6ft from the floor, can i build some sort of shelf that will minimize the noise from the fan? thank you!!
post #342 of 4908
one more question...the ceiling to projector number given...is that from ceiling to the top of projector, or from ceiling to the middle of the lens?
post #343 of 4908
You can't get 100" image diagonal from 13ft.
120'"-155" from ~ 13ft
Maximum distance for 100" ~ 11ft.
Mounting the projector:
Offset for 100" - 2,4" (center of lens will be 11ft away and 2.4" higher from top of the screen image)
Offset for 120" - 2.9"
post #344 of 4908
Well, the sales person was obviously optimistic, my tracking number says I will have it Next Monday here in the states. Good Luck all.
Hopefully someone will be able to give a good review before then, since this is my first ever PJ, and I havent ordered a screen, I doubt mine would be useful.
post #345 of 4908
I noticed in Projector Calculator that W7000 from 13 ft gives 35 ft, while W1070 gave 16 fl. Are not both supposed to be 2000 lumens? The good thing about this is I do not need ND filter, which was mandatory for W7000.
post #346 of 4908
Originally Posted by DavidK442 View Post
Like most low cost projectors this one is meant to be hung from the ceiling or set on a coffee table (like in the photo). The small lens shift will allow you to move the projector a little bit higher or a little bit lower and still hit the same screen, but it certainly will not allow you to mount it on a shelf aimed at the middle of the screen without physically tipping it and activating keystone correction to adjust for the resulting trapezoidal image. As I think has been stated before, this pretty much excludes this projector from being used with a high gain screen which requires the projector to be close to eye level for maximum brightness.
Unless you tilt the screen. Standard set-up for parabolic screens like my old gain 13 Vutec with bottom mounted projectors, is a forward tilt, with ceiling mounting you may have to hang it flat to the wall.
Edited by donaldk - 12/1/12 at 5:51pm
post #347 of 4908
Not sure about chip.
Can't wait to someone confirm 1700Lm after calibration (from Kraine's test).
post #348 of 4908
it's definitely dark chip 3, and the w7000's 6x color wheel only works in torch mode, assuming the w1070 works in all modes, normal, eco, etc. definitely looking forward to seeing if it is all true.
post #349 of 4908
I'm in the market for a new PJ myself and just wondering how this one stacks up against the Mits HC4000? A couple years back I had a HC3800(got nothing right now though) and liked it except for the RBE, weak black levels and wished it was brighter. I heard the hc4000 has better blacks now but the RBE and brightness are the same.
From what I uderstand(just from reading here) that the RBE and brightness are better in these PJ's(please correct me if I'm wrong though) but how does it compare with blacks, colors and sharpness? Is their anything you would guys would say is better about the HC4000 or do you guys think w1070 hands down?
post #350 of 4908
K after reading the entire thread a couple times it looks as though it may be too early for that question.
post #351 of 4908
humm, on that german forum: http://www.hifi-forum.de/viewthread-94-12408-14.html
there's a W1070 owner saying:
In Robin Hood, I enabled the Eco Mode and in some scenes (light/dark changes) I can see a step-like brightness correction of the entire image. I was told by a user that this is not unusual in Eco mode. In normal mode, this is not noticeable anymore!
So apparently the lamp brightness is variable and works as an iris, doing visible pumping in bright/dark scenes changes? And the only way to avoid that would be to run it in normal mode huh?
I guess I would have a few questions to early adopters before I'd pull the trigger please, including:
1) is there any pumping effect in eco mode as this owner said?
2) can you hear an audible difference between the 3 user mode presets? The w7k only runs the wheel at 6X in "dynamic" mode so this should be audible as the the two others(including "cinema") run at 4X only. I wouldn't be surprised if the W1070 used the same trick as 5X was a banding feast on my HC3100, 4X was just fine though.
3) is there any "neutral" sharpness setting? apparently there isn't on the w7k, it's either blurry or sharpened duh.
4) does it accept 1080p/48Hz? or only 24Hz?
5) how does the wheel speed audibly fluctuate between 1080p @24/25/30/48/50/60?
Edited by leeperry - 12/2/12 at 9:37am
post #352 of 4908
Personally I think it's foolish to "bake in" such image processing tech into a projector. Much better to use software and/or do all that on a separate processor upstream, which is independently upgradable.
I used this screen size calculator that has a drop-down option for the BenQ w1070 and realized I will have to be sitting quite close to the projector to get a good mix of brightness, screen size, and seating distance in my place, which means I will probably be building the custom enclosure for noise reduction. I had an idea to place it at the far back of my loft (30 feet from the front wall), so it would be out of the way, but this projector can't throw that far, and besides it would be way too huge, too dim, etc. It appears as though the closest recommended seating distance is a bit in front of whereever you place the projector, as others here have mentioned, around 12-16 feet is ideal.
At 13 feet, with a 2.35 : 1 screen, it'll be around 100-120 inches of screen width. A ten-foot wide TV !!! I can't believe I'm about to get this, kind of crazy when you think about it. Also, this forum is great, the 2:35:1 aspect ratio is very do-able via PC settings, I'm definitely gonna try and build a SILVER screen and constant height setup eventually. So what if the projector is so cheap, that's all the more reason to upgrade it in a few years' time. I honestly don't see anamorphic lenses going away. Some people were mentioning C-stock UH480s for like $650? would love to get some links to that, I could even get that sooner rather than later.
post #353 of 4908
It appears that there is still confusion about the color wheel speed on this projector? Anyone got any closer to determine whether it is actually 3x or 6x speed?
I am asking because I am considering to buy this projector to replace my old Mitsubishi HC3000 - which got a 4x color wheel - but I wouldn't like if the W1070 had more rainbows. Anyone got an idea how the W1070 would compare to my HC3000?
post #354 of 4908
well, I used to own a HC3100 and I'm seriously considering ordering it so I would gladly report back.
I've RTFM and apparently there are 3 settings for the lamp: eco, smart eco and normal. Only smart eco fluctuates the lamp power based on the incoming picture brightness, so vanilla eco should be fine.
I also read that on the w7k there wasn't any "neutral" sharpness setting, it was either blurry or sharpened.....so I would really appreciate some feedback on that matter too.
post #355 of 4908
Post of technically highly educated guy from russian forum (awful google transl):
chiv
"You seem to confuse the physical speed of light filter (color wheel) and an equivalent rate of change of the basis of color RGB, which indicate on the specifications and tests. Physical speed filter all DLP 7200/9000/10800 rpm, ie conditionally 2/2.5/3x. Duplication RGB triad already gives an equivalent rate 4/5/6x. In HD33 in 2D physical speed 2 (equivalent to 4), and in 3D mode filter accelerates to nat. 3 (equivalent to 6x).
According to prior data W1070 in all modes Phys. 3x equiv. 6x" link http://forum.ixbt.com/topic.cgi?id=62:20489-29#833
Also, Kraine asked BenQ France, they said it's 6x. From chinese review http://www.pconline.com.cn/projector/review/1211/3060242_4.html again 6x.
So, probably W1070 is better then HC3000 on RBE, you shouldn't worry about it.
Edited by Yusuf.0088 - 12/2/12 at 10:50am
post #356 of 4908
chiv
Also Kraine asked BenQ France, they said it's 6x. From chinese review http://www.pconline.com.cn/projector/review/1211/3060242_4.html again 6x.
thanks for that. that's what we've been thinking/hoping was the case. people should be receiving their w1070's this week so soonish we might get some reviews.
post #357 of 4908
Just bought the new Benq glasses D3, which is only 35 grams, less expensive than ZD201, 144hz refresh rate and almost double the contrast of the older BQ glasses. I also ordered 3Active glasses from Amazon. I hope 3D turns out as enjoyable as in W7000.
post #358 of 4908
chiv
Don't most budget DLP projectors have a 3x 6-segment color wheel on specs? Like the BenQ W1060 - which I've read can have more rainbows than other models? But if all projectors got either 2/2.5 or 3x physical speed then how could the wheel be faster (or appear faster) than the W1060 considering that W1060 got a 6-segment color wheel?
post #359 of 4908
I'm really curious to see how the D3 compare to the ZD201. Here in canada the price for the ZD201 was the same as the D3 so I went with the ZD201.
post #360 of 4908
Where did you find your ZD201s?
