AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$
BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 197
post #5881 of 8471
Originally Posted by pdxrealtor View Post
Anyone notice a very high pitch sound from this PJ when it's off and the room is silent? Almost exactly like that sound you get when you dim your lights almost all the way, but not quite to off.
I have that too. But this only happens on my second one. My first 1070 never had this. It may be the cooling of the lamp, may be something else. If I unplug the power cord, the very high pitch and very faint noise stopped. So it is somehow power related. I had this noise since day one but since nobody had mentioned it, I thought it might be an isolated case.
post #5882 of 8471
+1 - guessing its the PSU. I'm running at 220V input; are you guys the same?
Doesn't bother me much; also had it since day 1...
post #5883 of 8471
Glad your update worked out Ilia. I hear when you say the longest 5 minutes of your life. I'm probably the least computer savy guy on this entire forum. I had my share of difficulties getting the download to work but was really proud of myself when I got it to download. I had taken my unit down from the ceiling to do the update. I remounted it on the ceiling and powered it up and my heart sank. There was no BenQ logo and the menus wouldn't display. I thought I'm out of my league here and so I called and left a message on a friends answering machine. He is an electrical engineer and specialized in computer systems. I was going over and over everything I had done in my head and it finally occurred to me that I had put the lens cap back on to protect it during the remounting. Needless to say, I was ecstatic when It worked perfectly without the lens cap. I couldn't take back the voicemail though.
post #5884 of 8471
Haha... Happend to me on another occasion too...
post #5885 of 8471
Originally Posted by vagos1103gr1 View Post
Can you tell me please the brand or can you give me the link?
I believe this is the one I got... http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10113&cs_id=1011306&p_id=8204&seq=1&format=2
post #5886 of 8471
What about this ? http://www.amazon.com/gp/product/B0097K46FE/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1. Is gonna be ok with this? I already ordered. Is gonna support 3d?
post #5887 of 8471
You have to be careful with HDMI switches and 3D. I am using the following switch which is more expensive and very small. It does pass HDCP and will support 3D.
http://www.amazon.com/Sewell-HDMI-Bi-Directional-Switch-Passthrough/dp/B00629NHW6/ref=sr_1_8?ie=UTF8&qid=1376051660&sr=8-8&keywords=hdmi+switch
The first switch should also be ok since it will also pass HDCP.
Edited by rwestley - 8/9/13 at 5:47am
post #5888 of 8471
Will any of these HDMI splitters actually split the signal and allow video on two display devices simultaneously. The one linked above seems to be an either or solution, not a BOTH. I have a flat panel in a gaming area, and the projector in the movie room, that I'd like to feed the same source too simultaneously.
post #5889 of 8471
You need a splitter - not a switch. Check to see if your flat panel and projector are the same resolution - ie 1080p. Otherwise the lowest common resolution is the one that is feed to both devices. In other words if you have a 720p flat panel and 1080p projector (or vice-versa) they will both get 720p. You can get a passive or powered splitter but I recommend powered. Monoprice has several HDMI splitters, the one I own is the #8154 and it's been trouble-free. None of my devices are 3D. They have a new model (no reviews yet) that does 4K and 3D.
http://www.monoprice.com/products/search.asp?keyword=hdmi+splitter
post #5890 of 8471
Originally Posted by mrh1 View Post
I do have another problem with the 3d glasses staying in sync.
I do sit about 2.3meters away from the 200cm screen, I have to look up slightly, the bottom of the projector screen (white part) is just below eye level, don't know if this is a problem.
below is an email i sent to benq, haven't had a reply yet.
I have a problem when using 3d on my Benq W1070 projector using Benq 3D glasses (rechargeable ones).
I cannot get the glasses to stay in sync, works fine for about 30-40 sec then the lens in the glasses start to flash with a red tint and then goes almost solarized through the glasses, the picture on the screen is fine and just shows the blurred 3d image. You suggested a shorter HDMI lead as the one I'm using is 9 meters, have swapped it out for a 3 meter one, I still have the problem. This is playing back 3d Blue ray, but any 3d content give the same problem.
If I hold the glasses front first into the projector light beam, they sync straight away but then lose it about 30 sec after I have sat down.
The glasses are fully charged.
The projector is mounted inverted on a wall behind me and is projected onto a pullup screen.
Does anyone have any ideas....
Martin
I got an response from Benq, just wondering what peoples views of these glasses is.
Martin
Dear Mr Hamilton,
I just have a feedback from my product specialist, which confirmed that in the situation in which the projector sits behind the person who watch the screen, the second generation glasses have shown sometimes a similar problem of synchronization.
These glasses are now discontinued and at the end of the month the new generation will be released, which will not have any problems.
Alternatively, you can purchase the Sainsonic glasses form the link below. These glasses have been tested with the W1070 and works perfectly
http://www.amazon.co.uk/gp/product/B006CHD67O/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Please, feel free to contact us for any further assistance or information you may need.
Kind Regards,
post #5891 of 8471
Martin
Dear Mr Hamilton,
Kind Regards,
The Sansonic glasses do not do a great job blocking the red flash.
post #5892 of 8471
Martin
Dear Mr Hamilton,
Kind Regards,
Which glasses are generally considered to be the most suitable for the w1070?  I haven't really bothered with 3D so far, but a few of my Blurays came with a 3D version so I might just take a look. Thanks.
post #5893 of 8471
3D TV Corp and Dimensional optics are good. I like the Dimensional's a bit more, they do cost more then the 3DTV Corp's. There are other glasses as well but these are the only two I have tried. You can also check out this thread..
http://www.avsforum.com/t/1448720/benq-w1070-144hz-compatible-dlp-link-3d-glasses
post #5894 of 8471
Totally agree these are the best.
post #5895 of 8471
Thanks guys. Thanks for the links too.
post #5896 of 8471
Hello everybody. I have connected all my devices through the yamaha the-4065 and the hdmi out to tv but if I want to. Connect the projector I am gonna need an hdmi splitter cause the receiver has only one hdmi out. Do you recommend me any good one?
Good excuse to upgrade to a receiver with dual hdmi out?
post #5897 of 8471
Like everyone mentioned 3DTV glasses. Be surprise watching 3D with this pj. I don't want to watch 2D any more.
post #5898 of 8471
I tried the Dimensional optics glasses and I couldn't get them to sync at all, the glasses looked great and so was the tech support, but ended up with a refund...
post #5899 of 8471
Would the 3dTV glasses work on a 5 and 7 year old? Or would I need to get a smaller kids pair for them?
Any experience anyone?
post #5900 of 8471
It is very loose on my 7yrs old but still work.
post #5901 of 8471
interestingly the glasses Benq recommend for me are not 144Hz.... how strange is that...
post #5902 of 8471
I think you will find that if you look up Sainsonic glasses on ebay they are all 96 - 144 hz and not limited to 120hz. Amazon are lazy in updating the listings!
BUT ... contact them and ask the obvious. Keep in mind that many people find Sainsonic glasses to be poor. Check out the glasses specific thread mentioned above. I use and prefer these glasses but they have non rechargeable batteries, some people prefer rechargeable ones: VIP 3D DLP-Link 3D Glasses http://www.ebay.com/itm/130827722094?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
My other preference (for guests) are these: http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=281071032288&clk_rvr_id=508729301935 , much cheaper and just as good with rechargeable batteries.
Edited by OZReddog - 8/9/13 at 5:09pm
post #5903 of 8471
Something had to be wrong because I and many others have these glasses and they work great. I wonder if you got a few pairs of the older versions. I originally got the old ones from Amazon and had to return them. The new ones work great and they are the best glasses around.
post #5904 of 8471
Regarding the HDMI Splitter...
I have mentioned this before but get this one and be done... http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10113&cs_id=1011306&p_id=7522&seq=1&format=2
Jason
post #5905 of 8471
Strange I hear many people said this. But on my $17 ebay Sansonic glass I hardly see red background, if at all. I don't know how other glass can do a better job. A bit brighter?
post #5906 of 8471
Not strange at all. Just compare them and you will see the difference. I find the blacks are gray with the Sansonic glasses caused by not fully blocking the red flash. I have compared them to the 3dTV, Benq's or Dimensional Optics 3DActive ones and the blacks are better with these.
post #5907 of 8471
Jason
This is a very good splitter but you must be aware that when you change resolution you probably will have to turn the splitter power off and back on. It seems that all splitters keep the previous resolution settings. You also will not be able to send a 3D image to one set and a 2D to another.
post #5908 of 8471
Hey Guys,
I've recently bought this Projector and have one issue that I'm unsure of. Every time I use the Projector, after exactly 2 hours it will go to the Blue Screen and have "Source Checking..." for a few seconds then it will go back to what I'm viewing. I have a feeling it has something to do with the Projector, but I've looked through all the settings and am still not sure what could be causing it to do this. I'm using Smart Eco, could that be the problem?
My TV and Projector are connected to an HDMI Splitter, which is connected to my receiver. I've had no troubles with my TV, only this one issue with the projector. Any help would be appreciated.
post #5909 of 8471
Anyone has a link to the 1.06 firmware? They don't even have it on the Benq.ca !
post #5910 of 8471
The glasses that Benq recommended are definitely not 144Hz see link below..
http://www.sainsonic.com/3d-active-glasses/3d-for-dlp/for-benq/sainsonic-dlp-link-compatible-3d-glasses.html
