AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$
BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 260
post #7771 of 8478
I would recommend that everyone at least create removable velvet masks for their projector to cover the black bars during movies. I just did it for my w1080 and its a massive difference. The blacks in film are OK but the black bars are horrid grey, the makes them deep black and makes the image pop out.
I used cardboard + velvet + tape+ staples + Velcro to attached them to my drop down screen for easy removable.
All this costs $18 in Canada so I would assume the states would be much cheaper to do.
post #7772 of 8478
So I'm following this guide for some suggested setting on the w1070 and I get to a point that seems to make no sense:
"To try these, open the menus, and from the Image menu, select Cinema mode. Then go down to Advanced. Open it, then select RGB. Place these number in, replacing the defaults. The improvements should be pretty obvious. We recommend you then save your settings under User 1."
http://www.projectorreviews.com/benq/benq-w1070-projector-calibration-and-settings-2/
The problem is, Under advanced> settings there is NO RGB settings as they've listed. In fact, I can find no where in the menu where I can change the IRE settings as shown on that guide. Anyone have any suggestions?
post #7773 of 8478
I did the same.I was horrified by the gray bars,when I first install my 1080ST.After creating the masks I couldn't believe the difference.
Watching it on 120" 16-9 white screen.
post #7774 of 8478
The black bars on my w1070 look black to me; not grey at all....
135" 1.1gain 16:9 display here
Sent from my SCH-I605 using Tapatalk 4
post #7775 of 8478
Originally Posted by Bassoholic View Post
Thanks for link. I have some reading to do
is MadVR an addition to svp? If so where can I get that?
I have an HTPC with quad core AMD 4100 CPU and Radeon 6670 video card. I am currently using mediabrowser and play movie with WMC. Jriver MC19 sounds nice. I like mediabrowser the way it pulls in artworks from my mkv ripped movies. Can I still be able to use mediabrowser with jriver, svp and madVR installed? Sorry as I said I have some reading to do. Thanks.
You wouldn't normally use SVP frame interpolation and MadVR frame smoothing together. SVP also needs ffdshow decoding which is included with Jriver.
You wouldn't use mediabrowser with Jriver as Jriver already has the same functionality built in.
post #7776 of 8478
Originally Posted by Phatboy69 View Post
3D1080p 60 SBS is only useful for PC playback or on a player than can convert framepacked 3D 1080p 24 to 3D 1080p SBS 60 on the fly. Native 24p playback is smoother if your display supports that framerate (which the projector does), otherwise you need frame interpolation or frame smoothing on the player (PC or BD player) to make 60hz any "better" than 24p at 24hz. "better" is a rather subjective thing to each individual. As I said I prefer native 24p for just about everything compared to the motion blur(ghosting) and unusual movement and artifacts that Frame interpolation or smooth motion causes. When it comes to PC games however 3D 1080p SBS @ 60 is way better than 3D 1080i SBS @60 or 3D 1080p @24.
Native framepacked 3D 1080p 24 is also higher resolution than 3D 1080p 60 SBS.
I've had no luck getting 1080p SBS @ 60 Hz working on 1.08. When I have a 1080p60 source going to the W1070 through HDMI, the only 3D option available is Top-Bottom. I've tried both PS3 and AppleTV as a source, and played with the RGB output (high/low) with no luck. Any ideas how to get SBS enabled under the 3D menu? It works fine when I feed in 1080p24, of course.
post #7777 of 8478
Originally Posted by THe_Flash View Post
Not sure about CA, but I notice on the top-right to mid-right of the screen it sometimes appears as though you're viewing the screen through water. Sounds silly, but I'm not sure how else to describe it. This often goes away after the projector has been on for 15-20min though. It's very apparent on a solid color background. Anyone know what causes this or what the correct terminology is?
MIne too. Top right is very soft compared to the rest
post #7778 of 8478
You will need to force the appleTV and PS3 to output at 60hz and in RGB mode to get the projector to recognise the signal. The projector will also need to be in RGB mode.
post #7779 of 8478
Hello friends!
Does anyone try to connect Intel NUC D54250WYK with this projector?
I have an issue with connecting NUC with Benq w1070 projector via HDMI cable (v1.4).
When I connect them with HDMI cable the image on screen is in green color. At the same time, projector's menu is in normal colors. Here is a links with photos of "green screen":
https://dl.dropboxusercontent.com/u/7163440/NUC_GREEN_SCREEN/IMAG1267.jpg
https://dl.dropboxusercontent.com/u/7163440/NUC_GREEN_SCREEN/IMAG1268.jpg
https://dl.dropboxusercontent.com/u/7163440/NUC_GREEN_SCREEN/IMAG1269.jpg
post #7780 of 8478
How do I accomplish that last part? Getting the projector into RGB mode?
post #7781 of 8478
This is a known issue and it sounds like you need to move the location of your projector. I'm sorry to say there is no other option to fix this. eek.gifeek.gifeek.gif
Long story short: The 1070 / 1080 family of projectors has one setting for zoom that allows you to get a clear image from edge to edge cool.gif
1) Set the ZOOM to the smallest size the image can display.
2) Move the projector so the image fills the screen.
3) focus.
This is the ONLY setting the optics can support for a clear image. For more info, search my prior posts.
post #7782 of 8478
Very nice thanks for the detailed explanation with pics!
Do you notice and chromatic aberration (CA) colour fringing towards the edges of the screen? I believe the lens doesnt have CA coatings is that correct?
If so is it noticeable watching films?
Let me start out by saying that my configuration is not optimum by any means. My throw ratio is 2.35 (lens distance from screen / height of screen) which as you probably know, is below the 2.5 minumum (3.0 optimal) stated by Panamorph. But my personal opinion on screen size is that bigger is better - I strive for total immersion and an Ultrawide 2.35:1 display. I'm pushing well outside the optimal limits of the lens to achieve this. I have a 115" Elite Lunette Curved screen (image 45" tall) with a lens distance of 106". I could have improved the result by going with a screen height of 35"-40", but that would not produce the cinematic experience I was looking for.
You are correct about the lens not having CA coatings. The CA towards the edges of the screen are significant in my setup - obvious with test patterns, grids and the like. When watching films for the experience, and not to critically analyze or obsess the technical aspects of the setup, my experience is the CA is rarely noticed (if at all) by me or anyone else watching the movie.
I'm a real stickler for detail, a tweeker at heart, but honestly CA doesn't impact my enjoyment of the movie. To be honest, I am more influenced by the pincushion effect given my short throw ratio (not a fault of the lens) than I am the CA. I'm hoping in time I'll be able to recreate the theater in a much larger space - which will improve upon these issues.
I wrote a shader to correct CA with the Cinevista (or any others, it's programmable) and unfortunately a deal fell through before I could get it to market. If I ever do get the time to make it work and feel generous enough to release it to the Gen pop for free, I will let you know. Unfortunately I have too many projects on my plate right now. If I had my own lens it would be a different story, I would definitely have had it working by now, but the Cinevista I was supposed to get never materialized, so now there is definitely little reason for me to work on it other than pure charity, and if I'm inclined to buy an a-lens, it will probably be the 480 with the CA correction built in.
If you want the shader, you can ask your supplier and see what they say. If enough people bought this lens and want it, I could easily be induced to provide one free of charge to the end user if the terms were right. But as I said, i had a contract already and it fell though so there's no chance in hell I'm giving it away for free to benefit some corporation.
post #7783 of 8478
Go into "system setup advanced" > "HDMI Settings" > change "HDMI Format" to PC signal
post #7784 of 8478
Originally Posted by newchel View Post
Hello friends!
I'm using the i3-3217U DC3217IYE version without any issues.
post #7785 of 8478
I have two Intel NUC D54250WYK and same issue on both devices...
Recently I read about such problems and now I think that this is handshake or HDCP problem... That means, it is hardware problem and it could be solved with NUC bios or projector firmware update...
Or some good advice from forum member =) Support of Intel and Benq keep silence till now.
post #7786 of 8478
So basically the zoom is off? Pardon the ignorance, but I haven't hook up my projector yet rolleyes.gif
post #7787 of 8478
I've been playing with jriver that last couple days and like what it offers with features and audio wise. I have not paid much attention to video yet. All I did with video was set it to Red October HQ and of course it selected MadVR for me. Do you think jriver is all I need and is it better than svp for picture quality? Thanks.
post #7788 of 8478
Just a heads up TrueDepth is doing a contest were you can win a few pairs of your choice of 3d glasses and some 3d blurays, I have been using their glasses for a while now and love them and their customer service is excellent, so yeah if you want to enter here is a link.
http://truedepth3d.com/~cd52f9119b4da30
post #7789 of 8478
3) focus.
I could have sworn in your prior posts you observed that perfect focus could only be attained by setting the zoom to the *largest* size image, in other words locating the projector as close to the screen as possible. Is that what you meant? I have my projector at the farthest distance from the screen possible, in other words zooming to the smallest image possible, and one trade-off to that location for me is that I cannot maintain perfect focus across the screen.
post #7790 of 8478
Whoops!!! That is correct.. Sorry, my mind was swiss cheesed from Objective-c coding.
post #7791 of 8478
Finally got a chance to try HSBS at 60Hz this weekend. We did not enjoy the performance much at all. The picture quality using RGB 4:4:4 is decidedly inferior to the YUV 4:4:4. Juddering was quite noticeable as well. Ah well, it is good to have tried. It is back to watching them at 24Hz - glad that PowerDVD takes care of changing resolutions automatically.
Thanks for your help PB69!
post #7792 of 8478
That wouldn't fix my issue, and perhaps the person who commented on my post did not understand what I was attempting to convey. There is actually a swirling motion in my top right image. I'd equate it to heat coming off a grill or cement, and how viewing a landscape through that heat distorts it. I'm wondering if it isn't the initial heat from inside the projector causing this, as the issue does go away after about 15min. of use.
post #7793 of 8478
I've seen an image like that in posts from about 3 months ago. I believe it's from an issue with your bulb. Just wondering, how many hours do you have on your projector and what lamp setting do you run it on?
post #7794 of 8478
I have almost 900hrs on the bulb, and typically run in Economic mode.
post #7795 of 8478
As I said previously, I couldn't get 24p with SVP @ 60hz to look better than native 24p @24hz. So with our projectors I cant see the difference with 2d material. So Jriver MC19 with MadVR should be all you need to get the best 2D picture.
3D is another matter though and depends whether you feeding it SBS 3D or native framepacked 3d.
As someone above just noted there is a bit more frame judder with SBS 3D compared with native framepacked 3D, even at 24p/24hz, so using SVP or MADVR smooth motion with 3D makes more sense to convert 24p/60hz.
MadVR Smooth motion doesn't need much CPU or GPU but SVP needs significant GPU power and my GTX760 cant handle 3d SBS SVP 24>60. So I think in the end just using MadVR smooth motion is a better compromise when you need to remove frame judder if you want to run 24p 3D SBS material at 60hz.
post #7796 of 8478
The replacement should be covered under warranty. It may be worth it to search back in the thread history to see the results of other members.
post #7797 of 8478
^^ awesome. Thanks for a detail explanation. I think I am good with jriver with MadVR built in. Funny it all started here by you mentioning jriver mc19 for picture quality. I downloaded it and like it a lot for its audio quality and features which I care more than video. For video, I just set it for Red Oct HQ- that's it. Have not done anything else. Didn't realize there are so much more one can do with jriver. Thanks again.
post #7798 of 8478
Yes Im an Audio guy first and video is secondary to me too. But the out of box quality for video and the theatre view is pretty damn good. Its the tweakability of audio that's the real draw card for me, being able to do bit perfect audio reproduction from multiple sources and file types including SACD ISO's. Nothing else comes close.
post #7799 of 8478
So which is it? Zoom all the way in and scoot the projector closer, or zoom all the out and move the projector away? Sorry, I am just planning on mounting it tomorrow and I don't want to redo it!
post #7800 of 8478
I agree with vidkidd, the best focused image I got was max zoom (biggest picture) and shorter throw.  Keep in mind that if your screen is smaller than 110" or so this is getting very bright to use in a totally light controlled room.  Max zoom also gives you the most lumens and decreased contrast.  I find the black bars on top and bottom of a 2d movie to be grey enough to be annoying with max zoom on a 120" screen in total darkness, even on eco mode.
Also I found the black bars just fine if I moved the projector back so I was using about 3/4 zoom for a 120" screen.  The picture was still quite focused.  FYI this is only a difference of 7" of throw.  However I ended up moving it closer with max zoom because I need the extra lumens for 3d.
