AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$
BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 263
post #7861 of 8419
Hi, I updated  firmware version from 1.05 to 1.08, It finished ok but now the red light is always on, and the projector doesn't start after updating.
If I connect it to the Pc using the USB, the PC doesn't detect anything, so I can not repeat the operacion with another firmware version
ups! I doesn't sound well. Has it happened to anyone?
Any idea? Is it possible to reset the flash memory?
post #7862 of 8419
same issue happened to me. I sent it to Benq and they changed the motherboard
post #7863 of 8419
Originally Posted by fredl View Post
Why can't you mount it upside down below the shelf?
Just use appropriate nylon distances so the projectors cooling works and long bolts with washers.
Its on top of a bookcase to be precise....
post #7864 of 8419
Ough :(
did you have any problem with warranty?
post #7865 of 8419
There has to be some setting issue cause how else can I explain that amazing 3D POP OUT EFFECT for 3d movies from my Comcast cable on SBS 1080i/60hz
And not having Zero 3D POP OUT EFFECT when playing 3D Blue Ray movies from my PS3 on FramePacking @ 1080P/24hz
Unless movies like Pacific Rim, Avatar, or Tangled have No Pop out Effect at all ...
But I'm thinking its gotta be something else ????  Any to do with "Nvidia card or FramePacking @ 1080P/24hz setting" in projector/ or any other PS3 setting ?
Using True Depth 3D Glasses, work very well on the cable format atleast.... ?
post #7866 of 8419
Originally Posted by d19racing View Post
My projector auto detects the 3d blue ray from ps3 and sets it to frame packing format 1080p/24hz. But still not the same effect as wat I get with my cable 3d movies on SBS 1080i /60hz.
u think is there any other setting etc ??????
I believe it is because of the lower resolution in SBS 3D (vs. True 1080p Framepacked). When I looked into the 3D Bee 2D-3D converter, they note that 720p content in 3D will have ~30% stronger depth/popout than 1080p
post #7867 of 8419
Again, purchase a blu ray that you know has significant popout and test it (ones that you've already seen on comcast or the ones I quoted earlier). The films you're listing there have VERY little to no pop out from what I recall. There is no setting on the PS3 that will change what you're seeing right now. I have a PS3 as my blu ray player and have no problems with 3D.
post #7868 of 8419
Thanks again CheYC, & all other who have provided helpful insight towards my issue.
I shall do as advised. Will buy Journey to the Mysterious Island 2 on 3D Blue Ray and see if it plays the same way (displays 3D Pops Pout Effect) as it does when played from my Comcast Cable.
Will post my findings after comparing them.
post #7869 of 8419
This happened to my W1080ST when upgrading from 1.00 to 1.05. I bought an EPROM flashing device and will report back with my success / failure information in the coming days. If this fails, then I will have to buy a motherboard from BenQ as it is out of warranty.
post #7870 of 8419
ok, thanks about the informaticion
My BenQ is still in warranty, but I'm not sure if I'll have problems since I updated the firmware. This morning I'll take it to the store (FNAC) (fingers crossed...)
post #7871 of 8419
Originally Posted by Phatboy69 View Post
Firmware Changelog History of Benq W1070
Firmware 1.03
Problem-1- To improve the flickering when smart ECO mode + dynamic setting
Problem-2- To add “Background” color in OSD
Firmware 1.04
Problem-1- When at low temperature environment, fan oil would become thickened, cause rotational speed of
fan can’t reach target then shut down.
Problem-2- Keystone bug: When playing 3D (Frame packing), and then switch to 2D, and keystone value
can’t be kept.
Firmware 1.05
Problem-1- ISF setting cannot be saved
Problem-2- compatibility problem for some unique 3D DVD players(Philips)
Problem-3- OSD Swedish language of ”on& off” wrong translation
Firmware 1.06
Fixes:
-1- Hg bridge problem symptom: can’t turn on a projector, but NDF after transportation; few cases found in BQC.
There is Hg (Mercury) in a lamp bulb. Whenever the liquid mercury make the Short-circuit of electrodes of the lamp, the unit can’t
be turn on. To change the cooling status and lamp ignition behavior can make mercury condense at different locations of a bulb.
Due to Hg (Mercury) changing the location in lamp bulbs during transportation, it will be NDF in ASP.
-2- To improve power-on while system initializing
-3- To improve Philips DVD compatibility issue(BQC)
-4- Add 3D format as appendix
-5- Adjust Audio Curve for BQjp
-6- Japanese OSD correction for Cool and Warm (BQjp)
-7-To enhance HDMI searching speed
-8- To update RC code for new remote RCV011
-9- To modify the gain value to improve HDMI signal searching ability
-10- To add model name W1250 in Factory OSD (only W1070)
Added support for 3D formats:
1280x720p@59/94/60 Hz -- SBS added
1280x720p@50Hz - SBS added
1920x1080p@23.98/24Hz - SBS added
1920x1080p@59.94/60Hz - Top Bottom - added
1920x1080p@50Hz - Top Bottom - added
Firmware 1.07
- ISF Night setting can’t be keep after 2D->3D timing changed
- To keep lamp hour after “reset all setting in USE OSD”
- To improve the 32 gray level via PS3 HDMI
- Modify picture mode of “power off” icon
- Modify HSG setting in No signal condition
Firmware 1.08
- Noise improvement / 1080p greenish problem via HDMI/VGA signal.
- Add 3D support timing: 1080p 60Hz SBS
W1080ST Version 1.03 = W1070 Version 1.06
W1080ST Version 1.04 = W1070 Version 1.07
W1080ST Version 1.05 = W1070 Version 1.08
(Do not load W1080ST with W1070 firmware!!!! The changelogs are the same but firmware IS NOT compatible between different projector models)
All current versions of W1070 Firmware
https://www.dropbox.com/sh/x5omnxp1vr6wyi4/e8_HLKrQUV/Firmware%20Files
or
ftp://62.141.76.120/driver/projectors/W1070/ Username: username Password: password
Latest 2 versions of W1080ST Firmware
ftp://62.141.76.120/driver/projectors/W1080ST/ Username: username Password: password
Service Manuals
https://docs.google.com/folderview?pli=1&docId=0B_xTFybwtlbvTHFqclRLU3pBNlk&id=0B_xTFybwtlbvU1oxdHRNcWd3LTQ
Useful Test Patterns - Username: username Password: password
ftp://62.141.76.120/driver/projectors/Tests/Main_HD/
These links are I dead I believe. Ay chance of getting firmwares between 1.05-1.08 for W1070? If a member here does have firmware between 1.05-1.08 please PM me and I'll provide an email address. Also, where can I find a step by step process on upgrading. Thanks in advance smile.gif
post #7872 of 8419
The FTP servers work, but you need te login with username and password...
post #7873 of 8419
ok.. wasn't working on my ipad but was able to download everything I need on to my desktop.
Why are the instructions different from the ones in the service manuals for upgrading the firmware? Am i Missing something here?
post #7874 of 8419
Well I figured out what those line marks are from the projector. They have to be dust or parts of cob web inside the light box. I noticed today that they are moving rapidly from the fans on the projector. There is nothing in front of the lens either. I emailed Benq and filled out a form. I told them the thing is just 4 weeks old and would like a brand new replacement. I only have 50 hours on it and this happens. I thought the light engine was sealed.
post #7875 of 8419
Tangled has some great pop-out during the lantern scene when they are out on the boat watching it.
post #7876 of 8419
Yep, also when he is riding down the water flume with the water drops shooting out.
post #7877 of 8419
For those who updated firmware, one question. Do you see any difference in 2d picture quality going to 1.08 from 1.05? I am asking this in order to find out whether there is a real reason to risk updating firware (i play 3d from br, so do not need mkv 3d resolutions)?
post #7878 of 8419
Default color calibration values are now different; but that's not something you can't do yourself :-)
I'd therefore say in your case: not worth it.
post #7879 of 8419
With reports of a few firmware updates gone wrong lately, this might be a good time to evaluate whether an update is truly worth your while.
Amongst the numerous improvements made to the firmware, only some features are worthwhile to most.
Here're the big-ticket firmware items that probably make updating worth it for some users:
  1. If you transport your projector around a lot: you may want to be on at least 1.06 due to the Mercury Bridging issue that caused users transporting freshly powered-off W1070's to have their lamps fail on next power-on. BenQ improved both the power-off cooling process as well as the lamp-ignition procedures to reduce the likelihood of this issue.
  2. If you're bothered by slow Source Detection when switching HDMI inputs: you may want to be on at least 1.06 since this is quite a bit quicker here.
  3. If you need side-by-side 3D playback at full resolution: you may also want to be on at least 1.06 since Side-by-Side mode was added when running 1080p @ 24hz. If you play only 3D blu-rays (which are framepacked), you certainly don't need this.
  4. If your source device frequently drops out causing a 'No Source' message on the projector: you may want to be on at least 1.06 since HDMI gain was increased allowing the projector to hang onto input signals a bit better. In practice, changing HDMI cables may also improve this (especially shorter cables).
  5. If you need High Altitude Mode whilst running in Smart Eco: you may want to be on at least 1.08 since I've found that High-Altitude Mode was actually being ignored under earlier firmware when Smart-Eco was on (ie, the fan would reduce to regular speed after a few minutes of being powered on, to the same speed as when HA mode was off.)
If you don't fall into any of the above categories, it's probably not worth it to the average user to take the risk.
In my case, only the addition of 3D SBS mattered to me (which is why I jumped onto 1.06 in such a hurry) - conversely, my update to 1.08 was a waste of time (didn't notice improvements to picture quality; though default color calibration settings are now a bit better).
HTH!
post #7880 of 8419
Did anyone do a calibration on their projector with the new 1.08 firmware ?
If so can they put their settings on the forum?
Thnx!
post #7881 of 8419
If firmware is altering the out of the box calibration settings you'll no longer be as accurate as the 1070 has been known to be (out of the box). Of course that OotB accuracy will drift as lamp hours increase.
Each unit requires it's own settings for optimal accuracy due to many variables so unless you have proper calibration gear I would not be too quick to update the firmware unless an added feature is more desired than accuracy.
My unit is still on what it shipped with (1.04 I think) and I have not had any issues nor a reason to update.
Jason
post #7882 of 8419
Jason
W1070 and W1080ST are now more colour accurate out of box than on previous firmware. The default settings for colour are now close enough that an improvement would be hard to detect unless using calibration equipment. The brightness, contrast and sharpness settings previously recommended will still work fine with the latest firmware though.
post #7883 of 8419
If you update the firmware and that firmware changes the out of the box settings then your unit is not as accurate as it was previously (where it had the settings that it did due to a factory calibration).
My comment was not regarding new units coming with new firmware.
Jason
post #7884 of 8419
Jason
Well out of the box it is reasonably correct, but not right on the money smile.gif
Thats why they are still being calibrated.
If this firmware upgrade means you hardly need to calibrate it, it is a good update!
And I mean settings previous firmwares needed like this (http://www.soundandvision.com/content/benq-w1070-3d-dlp-projector-settings), which even with my projector does look allot better!
So I wonder if anyone measured the results after 1.08
post #7885 of 8419
It seems there may be some confusion here regarding the firmware updates and what they can and cannot accomplish. I am not certain if this is misunderstood or if I am misunderstanding the responses to my post. wink.gif
Applying a newer firmware that alters the settings (assuming the newer firmware(s) do indeed alter previously stored settings) will mean that the factory out of the box calibration is now null and void.
Obviously a firmware cannot calibrate your projector. I am not talking about the basics (contrast, brightness, etc.) I am talking about the primary and secondary color controls as well as greyscale (D65/6500K).
So anyone updating their firmware is losing that Out of the Box color accuracy if the firmware does indeed alter the previous settings (by erasing them).
Of course we all know that using the basic settings is generally pretty close but accurate color settings will vary unit to unit.
Jason
post #7886 of 8419
Well my projector is being exchanged directly with Benq. I was told that its a faulty DMD board, which is what causes those lines to start appearing. So with under 60 hours it's getting replaced. So Monday it's getting shipped out for a new one.
post #7887 of 8419
How often does this projector go on sale? Looking to get it for the $750 or so that I've seen most have got it for.
post #7888 of 8419
I have a question regarding the PC Signal option under HDMI options.
For my HTPC, I have Dynamic Range set to Full 0-255, Pixel Format YCBCR 4:2:2
Projector HDMI Settings is set to PC Signal
Does this make sense? Do have it setup correctly ? Thanks in advance for the help
post #7889 of 8419
Jason
Are you implying that projectors are individually factory calibrated before being shipped out, and so updating the firmware will lose this individualized calibration for older units? If this is how the process works, then your caution that "anyone updating their firmware is losing that Out of the Box color accuracy" makes sense.
I had always assumed the factory calibration was generic to the model, and so the new settings that come with newer firmware might be a slightly more accurate calibration than the older ones. I assume that's what others on here are similarly assuming, hence their comments which seem in tension with your perspective.
Can anyone clarify whether projectors are individually calibrated in the factory?
post #7890 of 8419
They are definitely not.
