Originally Posted by
Flavius
Scene Mode: General
Picture Mode: Standard
Backlight: 5
Picture: Max (but reduce to 85 or even 60 for 3D content to help with crosstalk)
Brightness: 52
Color: 60
Hue: 0
Color Temperature: Neutral
Sharpness: Max
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot Noise Reduction: Off
Reality Creation: Manual with Resolution 20 and Noise Filering Min OR Off, based on preference.
Smooth Gradation: Medium <-- amazing for gradients!
MotionFlow: Standard
CineMotion: Auto 1 <--- these two settings give best judder elimination without fake SOE look, and no artifacts in games either!
Black Corrector: Off
Advanced Contrast Enhancer: OFF for 2D content. LOW for 3D content to help with 3D pop AND reduce crosstalk!
Gamma: 0
LED Dynamic Control: Standard
Auto Light Limiter: Off
Clear White: Off (or Low if you don't mind bluish whites in some cases)
Live Color: Off
White Balance: Defaults EXCEPT set G-Gain to -6 to reduce the overly greenish yellow skin tones on people on TV. Does not affect green intensity.
Detail Enhancer: Medium
Edge Enhancer: Off
Skin Naturalizer: Off
Display Area: FULL PIXEL change it to this as soon as you get your TV!
ALL ECO SETTINGS OFF
HDMI Dynamic Range: Auto
Color Matrix: Auto
Flavius, thanks so much for these settings ! I tried everybody's and your's was THE BEST by far ! I would say almost perfect for me and ALL content. But I did make a few adjustments that I feel made it better for me personally. But I would have never been able to do it without yours as a starting point. And the adjustments I made are very minute.
I wonder if maybe my eyes perceive things differently than yours slightly ? OR if the difference is in our TV's not representing the exact same thing even though they are the same TV ?
Anyway, to help anyone else that might like my tweaks a touch better, or maybe so you can try them to see if it helps you on some content, I thought I would post them here.
1st off,,,, strangely, you were right about MotionFlow, and Cinemotion. I liked both those things OFF before. AND honestly, calibrating the TV with Spears and Munsil HD Benchmark, even there under the corresponding tests for such (motion blur, etc..) to have both them things OFF made it perform best. So thats why I originally said that. BUT under real life content movies, you are totally right man !!! With them off, there were some jerky pans, etc... With your settings, WOW ! Perfect. So I wanted to tell you that.
Also, I want to point out to everyone, that for me, to get the best picture, there needs to be SLIGHT changes made in ONLY 2 settings for every different movie, animation, game, etc.. BUT these settings are the best go to start point, and then ONLY change 2 settings pending on content.
The biggest difference in my settings from yours is "Sharpness". From what I see in ALL content if I use Sharpness at "Max" like you do, I see bad "Edge Artifacts". Unless our TV's are different and/or eyes are, I can't see how you can't see that ? Or am I trippin ? The next thing was Color. At 60 like you do I see slight color clipping and/or extremes. Especially in Reds. I like mine at 56 for all content.
Try these settings and let me know what you think. (again though, judge the content being used and tweak accordingly as I suggest for the 2 "movable settings") BOLD is the changes. My settings are tested ONLY on 2D content, cause thats all I watch or care about.
Scene Mode: General
Backlight: 5
Picture: Max
Brightness: 53 (when Gamma is on -2), 52 (when Gamma is set to 0)
Color: 56 (for most content), 60 (for some content)
Hue: 0
Sharpness: 24-36 (for Games and Computer), 50 (for everything else) - Above 50 = Edge Artifacting, and just gets worse as you go higher.
Reality Creation: Manual with Resolution 20 and Noise Filering Min OR Off, based on preference. (Sometimes
Resolution at 10 looks better for some video games)
CineMotion: Auto 1 (for nearly all movies and most games),
OFF (for some video games)
Gamma: -2 (for most movies and/or normal content) , 0 (for darker movies and/or content) (when set to 0, put "Brightness" to 52)
Clear White: Off
Live Color: Off
White Balance: R-Gain: -2, G-Gain: -6, B-Gain 0,
R-Bias -2, G-Bias 0, B-Bias 0
Edge Enhancer: Off
Color Matrix: Auto
Try those out and let me know what you think. :-) I swear if dialed in the right way for the right content, it creates a slightly more rich, more honest looking picture to me. I will try to take screen shots of examples between the two so you can see. Maybe it is just my set ? lol IDK.
2 things you didn't mention and I wanted to ask you about.... What exactly is "Video Area Detection" and "Super Bit Mapping" ? And what do you have them set to, and why ?
Hope these settings help someone :-D I'm loving them
Edited by JoelxD - 11/8/12 at 2:48pm
