Hello, I'm looking to see if anyone with experience fixing these tvs would tell me if its worth fixing the problem I'm having.
When I press the power button, after green flashes, the power led flashes 5 times every 5 seconds and the temp led flashes once every 5 seconds.
According to the service manual, this means that there is an abnormal voltage on 30v line.
It suggest to replace the power c.b.a, and if that does not work to replace the main c.b.a. then the tuner c.b.a.
When I picked up the tv I was hoping it was a matter of changing the lamp, but it looks like this might be too expensive and complicated to make it worth while.
Can anyone tell me if I could fix this myself and if I can fix for less than $300. Now a days, u can get a new lcd for around that price.
Thanks in advance!!!
