My Denon 4520CI is installed and in the basement HT, now it's speaker/bracket mounting time!
I had (2) pair of these Vogels BEK100 Speaker Brackets, bought 12+ years ago and never used.
They are rated for 25kg/55lbs, and are robust.
They are very strong, black steel, and can easily support my 17lb Mini-monitors.
http://www.paradigm.com/products/products-by-category/bookshelf/paradigm/monitor-series-7/mini-monitor
Will need to make some extension wood bracket to project these past my side wall acoustic panels, that is tomorrow morning project.
Being that they are mounted from the back they will present a clean look.
If I did not own the Vogels BEK100's, I'd be looking at some of the offerings out there that project bookshelf speakers out from the wall and tilt/rotate.
What I saw on Parts Express or cruchfield did not grab me as robust though for bookshelf speakers in the 20lb range.
Something like these from ebay, would need to do some math for 35 degree tilt down - it's probasbly sufficient, I'd rather have 45 tilt down just for safety.
My only issue with these is you'd be able to see the brkt hardware....
http://www.ebay.com/itm/4-Pack-Lot-Steel-Large-Bookshelf-Speaker-Side-Clamping-Wall-Mount-Brackets-Black-/310403424581#vi-content
Edited by mtbdudex - 12/30/12 at 10:22am
Item specifics
DESCRIPTION
This side clamping bookshelf speaker wall mount has been designed for traditional wood cabinet bookshelf style speakers or powered monitor speakers that did not come with a standard mounting point by the manufacturer or have amplifiers on the back. This mount offers 90 degree swivel both left and right, as well as 35 degrees of tilt. This speaker mount is ideal for mounting your professional bookshelf speakers in your home theater, sports bar, studio, etc.
Quantity: 4
Use this bracket to mount your large bookshelf speakers in your home theater, sports bar, studio, patio, and more.
Solid steel construction
Provides a stable and durable mounting solution for large bookshelf speakers
Side Clamping: will work with speakers from 5” to 11” wide
Optional screw holes on the side clamps for added stabilization of large wood speakers (not required)
Swivels 90 degree left and right
Wall Mounting Plate: 9.5” x 5” (H x W)
Measures 16” from wall to end of the mount
Load Capacity: 44 lbs
Color: Black
Mounting hardware included
DESCRIPTION
Quantity: 4
Color: Black
