AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Moving past 7.1 into 9.1/11.x/3D ObjectAudio in HT via AudysseyDSX/DolbyPLIIz/DTS Neo:X™/Auro-3D
Moving past 7.1 into 9.1/11.x/3D ObjectAudio in HT via AudysseyDSX/DolbyPLIIz/DTS Neo:X™/Auro-3D - Page 11
post #301 of 819
Originally Posted by Pain Infliction View Post
What matrix decoders do you have?
They are old Circle Surround ones.
post #302 of 819
Originally Posted by landshark1 View Post
After a few more months of usage, I still like NEO:X for height more than the PLIIz. Again, it seems "less" in front of you, and more "on top".
I think you want to put the height channels at up high as possible and as spread out the front wall as you can or at least directly on top of the mains. Also, make sure the tweeter aiming at the LP if you can too.
Fantastic! After sleeping on this for a few nights, I think it is best for me just to do what you said. If I feel the need to change anything, I could always add height speaker closer to the seating position. Thanks for the response not only from you but everybody else as well.
post #303 of 819
Has anyone here considered or tried putting the heights directly overhead (voice-of-god), as in ceiling above the MLP.?
There was an article in widescreen review some time ago when this had been discussed.
I have also heard that this seems to be the configuration in some of the new Dolby-Atmos cinemas..
post #304 of 819
Oh good so that means that I am not the only one who was thinking about this as well.
post #305 of 819
If not yet "in home", at least this is one step closer: the new Certified Auro-3D Home Theater demo room at Stassen Hifi's Palazzo AV store in The Netherlands did exactly that...
However, no identification of the installed Auro-3D decoder plus the presence of a Top Front Center speaker suggests this might still be an engineering prototype decoder based on the theatrical 11.1 speaker configuration, rather than a pre production consumer home product...?! cool.gif
_
post #306 of 819
Has anyone here considered or tried putting the heights directly overhead (voice-of-god), as in ceiling above the MLP.?.
Single worst location for a speaker (even worse than a single rear speaker behind the listener). As with rear speakers, better to use two or four overhead speakers, even when reproducing a mono overhead channel.
post #307 of 819
Seven months (starting after CES 2013) have now elapsed since DTS started showing a "revised" Neo:X 11.1 configuration with four height speakers on their website (link) but with no explanation for the change.
However, the revised Neo:X 11.1 speaker layout does seem to resemble the one virtualized in DTS Headphone:X . . . which is supposedly the result of combining existing DTS Neo:X processing and some technology acquired along with SRS Labs...?! cool.gif
_
Edited by SoundChex - 8/16/13 at 10:56am
post #308 of 819
I think Illusonic is the only vendor actually selling a home theater processor supporting a Center Overhead speaker at this time...? And their manual makes it clear that a "low" ceiling or "large" seating area calls for multiple overhead speakers playing the same signal...
"For large rooms, or rooms with little height, it may be difficult to position the top loudspeaker such that its sound reaches the listening area evenly. An array of two or four top loudspeakers, fed with the same signal, may be used in this case. Use gain trim (Chapter 6) to calibrate the level of the array."
And the theatrical venue overheads I saw in imm sound promotional literature were multi directional "dispersion style" speakers, rather than "direct" ones.
LEAD Technologies Inc. V1.01 LEAD Technologies Inc. V1.01
_
Edited by SoundChex - 8/16/13 at 1:07pm
post #309 of 819
Thanks for the fast responses comments gang.
Was just wondering; if anyone had actually had listening impressions with a pair in the ceiling above the MLP, or in the ceiling and forward of the MLP...?
post #310 of 819
Originally Posted by SoundChex View Post
I love how every time dolby or dts or anybody shows a layout of how the speakers are suppose to be, the room seems perfect every time. My listening position is definitely not in the middle of the room.
So is the "revised" NeoX going to come into play or is it how it is now? I would hate to put in ceiling speakers for the right location now and then have an issue because they changed it.
post #311 of 819
Before ripping apart a currently installed home theater room to add new surround speakers for these matrixed formats, why not wait a little bit and see what befalls object based audio in the UHD specifications. I'm sure there will be different recommendations than what is currently being offered by Neo:X, Prologic IIz, and DSX. Things are moving quickly in consumer electronics these days. Hopefully, things will get ironed out by 2014.
post #312 of 819
You are probably right. I can wait a few months and maybe catch some awesome deals through that time too, but I can't wait too much longer or else I get cold sweats and start shaking lol
post #313 of 819
Unfortunately the surround sound speaker configurations demonstrated at CEDIA in September and CES in January are often more like 'lab experiments' than pre-production versions. It's better to wait for the CEMs to start showing new product bulletins with detailed specs before you start planning speaker counts and locations for your next system!
_
post #314 of 819
By any chance do you think that they will have and answer this September or January?
post #315 of 819
Reading through the Dolby Atmos materials, it seems to me that the minimum small theater speaker configuration for Dolby Atmos is (probably somewhere around) 13.x, and somewhat resembling a superset of the 'old' and 'new' DTS Neo:X 11.1 setups.
My inclination might be to wire for all those 13 speakers in their "standard" locations, and to install speakers as needed whenever I changed processors . . . and to worry about adding overhead speakers later! biggrin.gif
_
Edited by SoundChex - 8/17/13 at 9:42am
post #316 of 819
_
When you look at the Atmos speaker layout you could break things down this way for home theaters:
It's the basic 7.1 home layout, but with side speakers for each row for more accurate panning (if you have multiple rows, that is, or just want more precise locations for sound effect placement), a set of front wide/side wall surround speakers aimed towards the listening space set somewhere between the front screen speakers and the designated side surrounds, and as many mirrored overhead height speakers as you have side wall surround speakers. And if you're so bold, two subs in the back for the surround channels for speakers that can't handle low frequencies (since sound effects are now encouraged to be full frequency). If you're blessed with a large space for a big scope screen, you could add two more behind the screen front fill speakers (center left and center right).
Sounds doable to me... if the powers that be see fit to give us object based surround sound that is just as powerful as the commercial venues. The equipment should be modular so you can plug in as many speaker locations as you see fit... just like the commercial object rendering decoders.
Edited by Dan Hitchman - 8/17/13 at 10:15am
post #317 of 819
I'm guessing that the 10.2 channel Vertical Surround System (10.2-VSS) that ETRI and Samsung are proposing as a candidate audio configuration for the Korean UHDTV system is not exactly to your liking!
ETRI-Samsung 10.2-VSS - plan view and side elevation...
The configuration adds a pair of Height channels (LH and RH) positioned at a 45° elevation (placed similarly to Audyssey DSX) to a 7.1 Standard surround configuration. A Center Height channel (CH) is located directly behind the MLP at an elevation between 45° and 90° (i.e. directly overhead).
Didn't DMP Records experiment with using a similarly placed "combination" overhead-and-rear-surround channel repurposing of the sixth (LFE) channel on some SACDs...?
_
post #318 of 819
Not a question of whether I like it or not, but a case of documented problems. A single speaker along the listener's centre line is going to be heard identically in both ears, causing the listener to momentarily think the sound is directly in front when it might actually be coming from above or behind. The solution couldn't be simpler: use two speakers (even if they're playing the same mono signal) spread at least 30 degrees from the centre line.
post #319 of 819
When I was in Hawaii we would only go to a movie if it played at the Ward Center Titan XC theater. It was amazing sound and picture. It was the Dolby Atmos and quite simply it is amazing. Well worth the extra few bucks and you get to pick your seat in advance! If this comes to home theater sign me up!!!
http://www.consolidatedtheatres.com/cinema/content/titanxc.asp
post #320 of 819
Just finished my set up of a 9.0 system, other than the center all towers and it sounds great. My listing is mainly on dts neo x all the time. Minus when I am watching att uverse, and the volume level sucks, so the neo x thx mode sounds great.
post #321 of 819
IMO, you pick a point in time to upgrade, chose your equipment from what is available, and live with it until something worth making a new upgrade comes along. I doubt having more than 11.1 ( or.2 ) speakers will ever be practical in my theater. Seems perfect right now !! Somebody may come up with something new, but I am not going to replace my new Denon 4520 for at least 4 years anyway. At that time we will see what is available.
post #322 of 819
If one allows on-wall speakers and cables visible then it will be easier to adapt to change in standards.
post #323 of 819
I don't mind on wall speakers however, I would never have exposed wires! That is too messy looking! I do agree with Craig on this subject. I am just going to do what is right now, actually in January, and just upgrade a few years later if needed.
post #324 of 819
Ok. I don't understand why people stare at cables in a pitch dark room while watching a movie, but I guess we're all deifferent. cool.gif
post #325 of 819
Sorry dude. I just don't want anything in my house to look like sh1t. Having cables out looks like crap to me. My opinion. My theater is not always dark. It is automated to do certain things during certain points of movies and tv. I am more anal about things than you which is ok. Your way is your way and I have no issue with that. That is how you like it or don't mind it.
post #326 of 819
HDMI 2.0 allows for 32 discrete channels, but I doubt we'll see that come to fruition as it would take up a heck of a lot of space on a physical, streamable, or downloadable format (at least if you have UHD video along for the ride). I would think that 9.1 discrete bit-for-bit lossless (24 bit resolution with choices of 48 kHz or 96 kHz sampling) + any number of meta-data controlled audio objects in a hybrid channel/object-based format would work just fine.
I don't care if it's from DTS or Dolby (or the studio can choose one or the other like on Blu-ray) as long as it moves surround technology and the sonic experience forward.
post #327 of 819
Originally Posted by cw5billwade View Post
When I was in Hawaii we would only go to a movie if it played at the Ward Center Titan XC theater. It was amazing sound and picture. It was the Dolby Atmos and quite simply it is amazing. Well worth the extra few bucks and you get to pick your seat in advance! If this comes to home theater sign me up!!!http://www.consolidatedtheatres.com/cinema/content/titanxc.asp
Yes ATMOS is a real reason to go to the theater, like you I can't wait until it is available in HT
post #328 of 819
All my wires are run in the attic. Switching from 7.1 to 11.1, and replacing the L C R wires with new 12 gauge wire for my new Martin Logan speakers, was a pain in the you know what. I'm finished for awhile.
Never mind the cost of all those speakers - my room would be covered wall to wall with speakers! There is such a thing as the law of diminishing returns. Which is why I don't own any $ 1500.00 or $2000.00 bottles of wine. smile.gif
post #329 of 819
Any pics of your new MartinLogan setup?
post #330 of 819
+1
