Originally Posted by bossobass
Why are you comparing 4 drivers to 1 and calling it dual drivers? Ahh, you're doubling the drivers AND the amplifier. Doesn't work that way. Josh probably should ping you on how to interpret his data.
UXL has almost 3X the displacement. The numbers verify that. Pretty simple.
Bosso, are you basing the above comment on the published xmax of the Dayton? Eventhough Ricci noted approximately 20mm of usable xmax on the HO after independent testing? That obviously has to be the case given the UXL isn't capable of 60mm of xmax.
