Originally Posted by
Gorilla83
My box is 23w x 25h x 28d and nets around 7 cubic feet so you will need somewhere around the same depth.
Check out the FAQ I wrote last week:
http://www.avsforum.com/t/1443078/new-to-diy-faqs-in-here
As for cutting holes in the baffles I assume you meant the bracing? That is possible, but I'm not too concerned about weight.
thanks, i will probably make it around 30d minus probably 1/16th or 1/8th of a inch however much my blade takes off. , since i have 2 sheets of 3/4" thick 5'x5' baltic birch that have been sitting around since last year, i pray it isn't warped yet. probably 24x26x30, its not that much bigger then yours, and my drivers take up way more space! do you think it will work out ok? or should i aim for something thats deeper, say 32" etc, Thanks!
i will probably put more bracing in mine, mainly because i have them previously cut out already for the most part. probably 3 braces instead of your 2 and lighten then up a bit
my biggest question is that with dual opposed, is there a specific distance between the motors? i ask because the drivers i plan to use are 12" deep from mounting point to back of motor if thats what you call it.
also if one driver was 1/4" off in terms of mounting on the baffle, would it matter asides from aesthetics?
will read your faq later on, i mean i do ok with diy its more about being lazy. i actually did parts of 1 sealed box, but gave up halfway due to too many projects, now i know patience and dry fitting is the key!
sorry if i am thread jacking, let me know if you wanted me to message you instead!
