Originally Posted by
Diesel 48
Ok, might be more confused now than ever.
I am starting off by building 2 subwoofer boxes. Each box will have 2- 18" Dayton drivers. Just like what Gorilla did. I am using his cut sheet so everything will be the same. Later on when my new theater room is finished, I want to add two more boxes with 2 woofers in each again. From the sounds of it my options are the CV5000 to run two boxes. When I build the other two I will need another CV5000 amp. Or buy an LG clone with the loud fain noise that I can hook up all 4 boxes to.
The LG with the sunon amp's straight from Sanway is not that loud. especially compared to the ep4000 stock, and definitely the crown xls5000. I don't know why everything things they are so loud, I sit less than 10 feet away from mine in a rack that is flush on the bar area wall and it doesn't bother me THAT much. Could it be quiter, heck yea, I plan on modifying the additional fans at some point soon anyways, it doesnt look that hard.
Diesel 48
Alright, cool. When wiring the drivers together what type of wattage am I trying to get them to? Not sure which amp direction I am leaning towards but I believe my equipment rack will be outside the HT room so an LG could be a possibility.
If you are wanting to end up with 8 total drivers, then get dual 2 ohm VC's you can start with four initially wired to 4ohm bridged for the CV. or just two (single cab) in 4 ohm stereo on the Berry, and then when you jump to 8 total drivers, they will wire up 4 drivers per channel at 4 ohm stereo which is a happy place for the LG clone.
