Originally Posted by LTD02
i don't really disagree with your points.
i'm just asking what the faults are with the bms coaxial or what the tradeoffs are with running a horn to the point where it becomes omnidirectional that you mentioned.
the only thing that i see to complain about is the on-axis frequency response. but that can be fixed because of the well controlled off-axis behavior of the horns.
The issue with the BMS coax is how it gets fairly rough above 6khz due to how the phase plug combines the mid and HF. Not a deal killer, but it is downside relative to a smaller CD like a DE250 or 4550.
Measure a compression driver without a horn and you will see what a mess it is. A similar effect occurs with using a horn that is too small for the range intended. Some fudging isn't a problem but running this horn down to 400-500hz is pretty excessive. That is why 18Sound specs it as only usable above 800hz. They aren't listing this as some sort of pro sound safe guard like you will see with many CDs. This is because it is less than ideal below that point. Frankly I'm not the best at explaining how or why this is an issue. There are papers supporting this and threads of infinite length on DIYAudio discussing it. It is one of the reasons the roundover is used on the SEOS and Geddes horns along with roundovers on the cabinet. Things get really messy when discussing horn theory stuff. Play around with Hornresp and the wavefront simulator a bit. That is a good way to visualize what happens.
I'm also not suggesting that it will sound 'bad' per se, as much as it is less than ideal. Of course, ideal is impossible in some sense. JTR has to design speakers that will sell. I think they do an awesome job of minimizing tradeoffs and have created a product that will work for many people.
