Hello,
I am thinking of moving to a larger screen for my dedicated HT room, from 104" to something closer to 110"-120"
The problem is I am limited on the sides of the screen... currently I have tower speakers on the sides, and basically the walls are limiting my ability to go beyond my current setup. So I am thinking of buying an AT screen so I can go wider and place the speakers behind.
I haven't researched for years this option, so wonder what there is today aside from the SMX line . I am on a reasonably tight budget. Would like to spend no more than $700 or so. is this possible? Also is moire an issue of the past?
