AVS › AVS Forum › Audio › DIY Speakers and Subs › BassThatHz Theater Build
BassThatHz Theater Build - Page 21
post #601 of 616
Originally Posted by Mfusick View Post
My wireless lasts months and I'm a heavy user of HTPC (almost exclusive )
I put 70 hours on it per week. 3500 hours per year.
post #602 of 616
You need another hobby... lol
post #603 of 616
I'm afraid to try the XLR output of the 105 to the clone, for fear of hearing an improvement, which would make me want to spend another $1000 in upgrades.
Did the soundproofing help you with your neighbors?
Haven't asked them; but it would only be for cases where I'm doing above 100db-C in the bass region.
post #604 of 616
check out the Razer mamba mouse, it has a recharge stand it just sits on at night, so it's always full charge, and its lithium ion battery. It's also basically the best mouse you can buy.
post #605 of 616
I'm a big fan of razer mice. It's all I use now. I have about 6 of them. I can't use a normal mouse anymore.
post #606 of 616
I'm going to try Dirac EQ in a few hours, see what it can do.
I hope it has ASIO support, no biggie if it doesn't, that's just my preferred socket.
I'm not a big fan of EQ, but I'll trying anything once...
At worst, I'm hoping I can at least use it as an advanced tuning debugger: placement, toe-in etc
post #607 of 616
New Emo prepro?
post #608 of 616
Here is my Dirac LR Mains Only Results: Pretty flat!
This is the first EQ that I can truthfully say didn't impact the sound quality, heck it might have even improved it a bit. More listening is needed...
The good news is that it does support the 105's ASIO driver, however I'm not sure if it is using that or not truthfully and not dropped down into the Winblows driver. (I have no good way to confirm or deny).
New Emo prepro?
No. Just my HTPC.
post #609 of 616
I was clipping the Dirac, so I had to lower the bass boost. Silly BassThatHz for wanting all that extra bass. biggrin.gif
post #610 of 616
Are you using a Datasat processor for the Dirac?
post #611 of 616
Here's a video of Dirac EQ in action, 24/96 ASIO with ES9018 DAC.
With the subs and EQ'ed flat:
My HTPC runs it. Which has a Quad Core i7 3820 Sandy-E processor @ 3.8GHz and 64GB of Quad Channel ram... it's like 1% cpu usage LOL.
post #612 of 616
Are you sending HDMI to the Oppo ?
post #613 of 616
You use this simply as a HTPC or you game or do other stuff on it ?
post #614 of 616
How much can one get this Dirac software for? I love building computers. biggrin.gif
post #615 of 616
Around 650$.
It appears to be missing from the Dirac website, www.dirac.se/en/consumer-products/dirac-rcs.aspx‎ doesn't seem to work.
post #616 of 616
I'm using USB. HDMI would work too.
Around 650$.
http://www.dirac.se/en/consumer-products/dirac-rcs.aspx
