I have an Onkyo TX-NR5007 receiver and have had nothing but problems with it and wish to move to a simpler solution. In my lounge I use an HTPC as a daily driver, and this uses an Asus Xonar DX sound card which provides 5.1 channel playback - even with stereo sources. I have this connected to a 5 channel power amplifier and a sub, so this setup is completely receiver-less. I love that I can just use the volume control on the HTPC remote, and most power amplfiers sound better than equivalent priced receivers anyway.
Onto my problem - I have a 7.2 channel setup in my theatre, and want to get rid of the aforementioned Onkyo receiver but not the HD audio decoding (which incidentally doesn't work at the moment. I want to purchase a sound card that will do all of the decoding on board (HD audio, DD/DTS, Stereo) and provide these outputs to power amplifier monoblocks. So far the only two options that I seem to have available to me are the Asus Xonar HDAV 1.3 Deluxe and Auzen Hometheater HD.
Will these cards provide 7.2 channel surround to stereo sources like a receiver would?
If I am using the card to output an analog signal, do I still need to pass the HDMI cable out of the Video card (ATI HD6450) back into the sound card, and then off to the projector?
Has anyone used either of these cards in the scenario that I am proposing? What did you think of the performance compared to a dedicated receiver?
Thanks in advance.
Thanks in advance.
