AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung PN60E530 Owners Thread
Samsung PN60E530 Owners Thread - Page 4
post #91 of 129
Having a small issue and I'm not sure if it's been discussed. I was playing a Xbox game (NBA 2K13) and every 20 seconds or so there would be an ever so slight brightness change. Almost like a flicker. The screen would brighten every so slightly and then repeat 15-20 seconds later. Has anyone else noticed this or is there a setting that you would suggest?
Thank you.
post #92 of 129
I had irritating flicker in dim-to-bright and bright-to-dim transitions on my 2010 C-series for a year and a half before I tried a picture configuration that changed my white balance. I haven't seen a single flicker since. Try a config that switches up your white balance.
post #93 of 129
Thanks for the suggestion. I'll give that a try.
post #94 of 129
Well my firmware dilemma is finally over, tech came out and replaced the whole main board which of course has FW 1018.1. TV back on the wall finally smile.gif
On a side note, I did put some football on and I definitely don't see the motion blur issues I saw with our first TV, which was on FW 1012.3. I'm not sure if that TV was version TS02 though.
post #95 of 129
That is wonderful news! Now, hopefully Samsung puts the latest firmware on their support site.
post #96 of 129
Newbie here. Just got this one from Amazon.few questions.
1. I was told delivery guys will also setup the TV and make sure no issues - also implies if there are any issues I find later, they would be considered new issues than issues at delivery. Can you tell me what all I need to get checked when they deliver it.
2. Is it true that one shouldn't caliberate when the TV new. If true, what is the reason behind it.
Thanks. Appreciate any newbie tips on how to get the best out of the TV and how to maintain it well.
post #97 of 129
Delivery guy delivered the tv , put it on stand and made sure screen shows up. Now I have 30 days to report any problems, at first look everything looks fine.
1. What exactly you guys mean when you say blacks are good. I know RGB make up all colors but not sure what is special about black color and how do I verify?
2. Also what is white balance?
post #98 of 129
I've only had this tv for less than 4 months and today it bit the dust, No power! mad.gif Tried several outlets with no luck. Luckily it's still under warranty.
post #99 of 129
Anyone experiencing the auto-muting or auto-dimming of whites on an all white picture? I assume this is to protect the TV. Can you turn this off? How?
post #100 of 129
That is ABL(auto brightness limiter) is shortcoming of plasma technology the last few years, there is nothing you can do about it really
post #101 of 129
Just got this at BB. Yesterday
Their decently knowledgeable TV salesman helped augment my decent knowledge of TVs enough to pacify my plasma concerns. I've had 2 samsung LCD Monitors and 1 LCD TV (LNT4665F-mid tier 2008 model) so im pretty confident in the brand. What warranty did yall had? BB in house warranty? squaretrade?
I got them to pricematch down to $880 and I had $20 in reward certificates so out the door was $951 in Texas. I think I got a solid deal (most places are selling for $1k) although it appears it was less at some points in the past.
I am on FW 1018.1 FWIW
post #102 of 129
is it just me or is the buzz louder on different inputs?
post #103 of 129
I just got this TV and I'm unsure if it supports ARC on its HDMI imputs?
post #104 of 129
I have had this TV since Oct. They had it as an open. Box at Bb for $649 so I scooped with a 2 yr warranty. Mfg in Aug. When I got it home and hooked it up, all the whites showed up pink. BB(geek squad) came out a week later and replaced everything but the bezel. TV has worked great since. Til recently, now im starting to notice a pinkish haze in mostly white scenes. Has anyone had this issue. Its has been disc calibrated through a ps3.
post #105 of 129
My firmware is t-mx9fausc-1014.1
post #106 of 129
On mine when the screen is mostly or all white there is a bit of pinkish haze but it's only slight.If you can pause on all white screen turn down color to zero,then turn red gain down until red haze isn't so red.then turn red bias up about the same amount as you turned red gain down.if the darker parts have too much red then turn bias down until it's not obviously red.
Edit turn red bias up about half of what you turned red gain down.
Edited by Vic12345 - 5/2/13 at 5:42pm
post #107 of 129
I will try that when i get home. If isn't in your face obvious "pink"but enough to notice
post #108 of 129
Does anybody know if the newer model pn60f5300 stand will work onthe 60ef530, pretty much the same except the one is 2012 and 2013.
I hate my stand on the 60e530, way too wobbly!
post #109 of 129
Anyone else get in on the killer deal Dell had? 997.99 with a 500 dollar gift card. After buying three gift cards with 150 dollars in promos (100.00 of which you could apply immediately and bring the price of the TV down around 960 shipped) With their Advantage program giving another 50.00 after shipping, To sum it up, I got the TV for 964.00 shipped with 600.00 in promo giftcards to use in 20 days. Pretty awesome.
Some of the reports of buzzing and other oddities with this set scare me, but I'm hoping I get a good set (with updated firmware!)
Edited by FriendofSonic - 5/13/13 at 10:03pm
post #110 of 129
I did. I was glad to get in on it, and did so similar to you (gift cards, etc.).
Thanks to Optimus for the calibration settings.
I downloaded some burn-in slides. I am still unclear if I do the slides for 100-150 hours prior to setting the set to Optimus's settings. If yes to that question, what settings should the t.v. be at for the slides? The out-of-the-box settings? Thanks for any info!
Edited by graycf - 5/14/13 at 7:03am
post #111 of 129
I downloaded some burn-in slides. I am still unclear if I do the slides for 100-150 hours prior to setting the set to Optimus's slides. If yes to that question, what settings should the t.v. be at for the slides? The out-of-the-box settings? Thanks for any info!
Awesome to hear! Hope we both get the best panels! (Which one is the Samsung panel, if they made any panels for this size and model?) And I echo Graycf's questions since this is the first time I've ever owned a plasma and I want to break it in right.
post #112 of 129
Originally Posted by **OptimusPrime** View Post
Yes, mine is TS02.
If you go to your ""Support" menu option, and tab down to Contact Samsung," press page down on the remote and it will give you the firmware version.
Wow, I guess I need to get firmware upgrade mine is only 1011.1
post #113 of 129
Btw, is there a Better stand for this plasma? Factory stand is wobbly!
I am wondering if the newer F5300 stand will work, looks the same other than the stand looks better??
Ideas?? Other than mounting, I can't do because of a large pass thru window frown.gif
Edited by MrSmartJohnson - 5/14/13 at 1:32pm
post #114 of 129
Just talked to Samsung. They are denying anything about a newer firmware other than 1012.3. They're are sending me a free usb flash drive with it on it. Mine plasma came with 1011.1. Even though others have posted having 1017.1 or 1018.1.
P.s. if any nody wants to know, they advised me if I used website for warranty they would give me an additional 3 months vs sending in warranty card! smile.gif
Edited by MrSmartJohnson - 5/15/13 at 3:31pm
post #115 of 129
Crazy. I can't believe they won't put the latest firmware file on their support site. That is absolutely ridiculous. Glad they are sending you an update. Too bad it isn't the latest version.
post #116 of 129
The firmware situation sounds ridiculous. Hoping mine that's coming in the mail is up to date .
post #117 of 129
If it is, PLEASE consider sharing the file with the AVS community. It is sad that we have to go to these lengths to get the most recent firmware.
post #118 of 129
I definitely will do anything I can do to help. Will it be difficult to get the firmware off of the TV? This is coming from Dell, and I know they've been running sales on the TV prior to the monster sale they had when I bought it, so I'm really optimistic about it being a fresh unit from Samsung.
post #119 of 129
Oooooh. Gotcha. I misunderstood you. I thought they were sending you a USB flash drive of the file. Oops.
Yeah, I am not sure how to pull the file of a television unit or if there is even a way to do so. Looks like you need to keep your fingers crossed your tv ships with the most recent firmware. I guess the rest of us are "sorry out of luck."
Please let us know what firmware your TV has once you get it. I am curious.
post #120 of 129
Just received this tv and confirmed firmware is 1018.1.
