What's happening to me is that the "Get notified when others reply?" setting at the bottom of the "quick reply" section is always "Immediately" by default (except on this topic, where the default was set to "Don't Subscribe"). If I use the "Post a Reply" button, the default notification value is the last one I used. So, if I use the "quick reply" field and don't change it from the default, it changes the notification mode for the thread.
This has got to have been something that changed recently; otherwise I'd have expected to have seen the problem before now.
EDIT: It just switched it to "Immediately" after I made a minor edit.
EDIT EDIT: It switched it to "Immediately" after the prior edit, even though the value at the bottom on the editor dialog was "Site Only" by default. Pretty hinky.
. Thank you very much
