AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Hard choices: Yamaha RX-A820, Denon AVR-2113 or Denon AVR-2313
post #1 of 9
Ok....
I am upgrading my setting. Currently I have Yamaha RX-V667. I want to go step further.
Importnat things are:
-Spotify should work
-Android tablet can be used to control and stream music or spotify
-Good quality
Nice to have
- Two hdmi out puts
-Reasonable price
-Two zone possibility...no need to listen at the same time in two zones using different sources
Prices in Europe...
Cheapest from those three is Denon AVR-2113...which is around 470eur
Then Yamaha, which is around 850eur and last one is Denon AVR-2313, which is around 950-1000eur.
Which one I should choose? My speakers are Aurelia Magenta (6 ohm) and subwoofer is SVS cylinder shaped with 400w amplifier and DSP.
I have 5.1 that I am using, but I also listen music.
Is there reason to pay 1000eur from Denon, is it really better than Yamaha? Help me in my decision.
post #2 of 9
Anyone? I was also thinking possibility of Onkyo TX NR-616 or Yamaha RX-V771...which are around 550€-600€ in price. Any recommendations?
post #3 of 9
post #4 of 9
You can probably take the 2113ci off the list as it only has one HDMI output.
post #5 of 9
It would be much less expensive to add a 1:2 HDMI splitter to the 2113 if none of the additional features of the 2313 are needed. Also, note that although the 616 has more features than the 2113, it also has the lowest version of Audyssey 2EQ so cannot even EQ a sub (neither can the 717 for that matter).
post #6 of 9
Ok. I am not sure about the features of 2113, as it seems that price popped up 150€, as it is not that cheap anymore. I don't have need for that Pro Calibration thing that 2313 have as feature...don't know if there are some big difference between 2113 except HDMI out? Is there?
Almost forgot to ask...how about Marantz SR5007...? Is it similar to Denon AVR-2113...comparison pretty hard to do? It seems to be almost the same, except the good outlook.
Edited by okster - 10/29/12 at 11:23am
post #7 of 9
I decided to buy Denon AVR-2313. We will see how it works. I will write some info to here, when I have tested it. Maybe after 1.5 weeks or so.
post #8 of 9
Hello okster, how is your experience so far with the 2313 receiver?
post #9 of 9
