AVS › AVS Forum › A/V Control & Automation › Home Automation › I need a new lighting solution
post #1 of 2
any ideas for updating lighting
Currently have 3 X10 wirless switch dimmers. Each are on a single pole set up.
One controls area near mini refrigerator which is right when you enter the room
the sign is controlled by a X10 wireless appliance plug in device
Second one is in a hall way.. two scones lights
third one is in the main room.. controlling four can lights
Motorized Projection Screen (Somfy Motor) w/ RF Remote - Matte White Fabric (106 inch, 16:9) Monoprice item number 6582
needs to be wireless, one remote for all..maybe something that can go to a Logitech remote when i finally up grade that.
Thanks for the help
post #2 of 2
Micasaverde with iRule should work and you can keep your lights. Micasaverde works with X10 and Z-wave and iRule can control Micasaverde.
  Back to Forum: Home Automation
