See if you can solve this one...
I have an AV Amplifier setup problem that i've been trying to work out for 2 evenings and still havent managed it....
Equipment:
Amplifier: PIONEER HTP071
Blu Ray: PS3
TV: Samsung UE40C6510 40-inch Widescreen Full HD 1080p 100Hz Slim AllShare LED Internet TV
Problem: TV sound is not coming out the amp (PS3/Blue works perfectly)
Connection setup:
- HDMI from PS3 into the Blu ray input on AV (works fine when BluRay input is selected)
- HDMI from the Output of AV amp to the HDMI/DVI input on tv (this should transmit audio down the ARC apparently)
Additional steps taken so far
- Switched on ARC (Audio return channel) for the HDMI lead on the TV source on the Pioneer amp
- Switched tv to external speaker within Samsung settings
- Tried connecting with optical audio cable instead (still no luck)
Can you see what i'm doing wrong?
Equipment:
Blu Ray: PS3
Connection setup:
). If you have cable, you can connect the coax from the cable box to the Cable/Ant input on the tv, select cable for your channel selections, scan, and you're done, hopefully.
