AVS › AVS Forum › Video Components › Video Processors › iScan VP-30 Will Not Auto-select the Input Source
post #1 of 2
Greetings to all. I have an iScan VP-30 with three HDMI inputs coming from a satellite box and two DVD/Blu-ray players. Each input works fine when manually selecting the input. I cannot seem to make the auto-select input function work for me. I have the three HDMI inputs set as priority 1 thru 3 respectively. I cannot seem to figure out what additional setting or settings I am missing to make the input auto-select when one source is turned off and another one turned on, etc.
Any thoughts on what I may be doing wrong would be greatly appreciated. Incidentally, my VP-30 has the latest firmware installed. Thanks in advance!
post #2 of 2
If I recall the satellite box is the problem since is sending a signal even when "off". Try disconnecting the box and see if it works then. I used a Harmony remote and changed input with it as part of the activity sequence.
  Back to Forum: Video Processors
