Just bought the new 82' Diamond series Mits and let me tell you.. its beautiful. There are so many options to adjusting that I dont even know where to start. I did buy Avengers in 3D but that to can be tricky. There are several options to adjusting 3D.
I'd like to get it Calibrated but they say you should wait 200 hrs...
I also added the LG 3D Blue Ray player, used monster HDMI cable, hooked up my xbox and PS3 and Cablebox. I will have to figure out how to hang my JBL center channel as there is no room for it. It matches the white wood so its got to stay.
My room is brightly lit during daytime so that can be challenging but the no glare screen makes a difference. And you can see how big that wall is considering this tv is 6ft in length.
At night its no different then a movie theater, with the exception to me being in my PJs..
Any suggestions on first time adjustments?
