AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha A-S500 amplifer for b&w cm1 speaker?
post #1 of 2
I m considering to get b&w cm1 speaker and musical fidelity m1dac a. Do you think Yamaha A-S500 amplifer is a good combination for those speakers and dac? I cant afford more than 600 dollars for integrated amps. Thank you!
post #2 of 2
If you want an integrated amp the Yamaha should be fine. I've noticed that Marantz and B&W pair well together. Another option would be to go with a receiver with bass management. IMHO, the CM1s sound best with a subwoofer.
