AVS › AVS Forum › Other Areas of Interest › Camcorders › turning off button sounds
post #1 of 3
Hi
I've purchased a HDR-AS15 to replace a GoPro but wish to silence all the sounds that the camcorder does when turning on/off etc. Does anyone know how to do this....? Sony say that it can't be done but I'm hoping someone out there has been able to over ride these sounds.
Cheers
post #2 of 3
There is no way to mechanically turn of the settings sounds when you press the buttons. BUT, if you control the camera by WiFi it may not make the sounds, as no on-camera buttons are pressed. You have the wifi version, and both an Apple and an Android app is available to control all the settings (and view in real time). Try this - I have not checked whether sounds are made via remote control.
post #3 of 3
Have their been any developments with this? Does using the WiFi control stop the noises?
  Back to Forum: Camcorders
