Try this in Excel:
1. First work out your throw ratio (TR):
Where H = Image height:
TR = THROW * 0.5625/H
2. Then calculate your pincushion as a decimal fraction of your screen height (using what you asked for, a formula):
Pincushion Percentage (PP) = 4.21/(100*{TR}^1.910963)
(if you multiply this by 100, you get Pincushion Percentage)
3. Then the result you want, the Pincushion... the actual amount your image corners will be higher (or lower) than the image center:
P = PP x HIn your case...
This all works out to
- Throw Ratio (TR) = 1.75
- PP (Pincushion Percentage) = 1.45%
- Pincushion (P) = 0.84"
- BONUS FACTOID: Needs a 38' curvature screen to cancel P (40' standard size is OK).
What's the formula based on?
Some research I did into pincushion when designing my Xeitoptics cylinder lens.
I found that pincushion was a straightforward function of throw Ratio (TR) for my lens design. The formula was derived from establishing a whole bunch of accurately calculated pincushion results in a spreadsheet table and then performing a statistical regression on them. The formula above in (2) gave a "best fit" regression.
I wondered whether it worked for other designs, even prism systems.
So I then tried it with models of other designs that I had, including prism lenses and old-fashioned designs like Isco. The results from all types of designs conformed pretty well (within 1% of the modelling results).
I decided the formula was generally usable
provided the throw ratio was not lower than 1.5 (yours is OK, at 1.75).
Ideally the best way to model these things is with optical design software. That's precise to thousandths of millimetres.
Next best is something like the spreadsheet I authored. That's precise to hundreths of millimetres.
Last best is the formula above. It's only precise to tenths of millimetres, and It tails off at really small Throw Ratios a little (still pretty accurate, though).
But be reassured, I modelled your setup using all three... and the results were all within 1/50th of an inch of each other.
I provided the formula because you asked if there was one. Given the caveats above, there is.
Edited by Aussie Bob II - 10/31/12 at 6:14pm
