AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Sub for $150....
Sub for $150....
post #1 of 15
Forgive me for asking, this forum is mind numbing.
I just ordered the Jamo 426 package to replace a BA MCS-90 package (hope this will be an upgrade?) and need a sub that wont break the bank.
I dont need ultra low extension but i do not want one note boomy bass. Down to 35hz or so would be fine.
my room is not small but not huge either...
thanks for the help, mark.
post #2 of 15
I ... need a sub that wont break the bank. I dont need ultra low extension but i do not want one note boomy bass.
IMO, you'll be hard-pressed to find anything at ~$150 that meets your requirements. I suggest you keep an eye out for a gently-used Energy S10.3. smile.gif
Roughly how big (l x w x h) would that be?
post #3 of 15
15x20 but is open to rest of house, also does not have high ceilings.
also i am not unhappy with the little sub that came with the BA MCS-90. it does add bottom to the sound... so i dont need liver shaking bass....
I should note that i did use to have the top of the line paradigm sub at one time ($1500). and paradigm all the way around, but divorce took care of that!
My wants are dictated by my means... i cant afford alot now.
Edited by mark62 - 10/31/12 at 3:51pm
post #4 of 15
Fair enough, which is why I suggested something that would fit your budget. smile.gif
post #5 of 15
Velodyne VX-11 is close to your price. Sounds pretty good for a budget sub. Won't fill a very large room with bass (only a 10").
post #6 of 15
the martin logan dynamo 300 is in your budget
post #7 of 15
what about the polk psw10, i would guess it is crap? i like the velodyne for 169.... any other recommendations?
post #8 of 15
The PSW10 is inexpensive (usually $99 on sale) and its performance is commensurate with its price. IMO, it is best suited to smaller rooms and/or modest HT set-ups.
post #9 of 15
ok one more question.... does anyone know anything about the pure acoustics lord 10? it is 119 with free shipping.... thanks again.
post #10 of 15
Having bought several sub $200 subs in the past, I would save a little. For $200-$250, you can find much better subs on sale.
The thing is, shipping a sub is expensive, so you're $150 sub is really a $75 sub. A $225 sub is really a $150 sub. For $75 more, you're getting twice as good a sub.
post #11 of 15
... does anyone know anything about the pure acoustics lord 10? it is 119 with free shipping ...
According to Pure Acoustics, the Lord 10 has a "200 Watts (150 max)" amp and a FR of 40-200Hz +/- ?dB. According to Amazon.de, the Lord 10's amp is rated at 150W RMS.
Edited by eljaycanuck - 11/1/12 at 10:12am
post #12 of 15
thanks for the replies, after searching it looks like the lord 10 was actually part of package system from pure acoustics... called the lord 10 also, i think im not interested.
would the dayton audio 1200 blend with the jamo 426 package? or maybe i should go with the 1000. maybe i will wait for awhile, i dont know
thanks.
post #13 of 15
Maybe this for $100. Looks like shipping is waived..... (don''t) really know.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
I've got 2 10" Dayton Titanic subs.....they are kits for $400, so I don't know how this would stack up.
The kits are pretty damn good....so maybe this would do (temporary).
vardo
post #14 of 15
will the dayton audio sub 1200 blend with the Jamo 426's? i know it would with the mains which have 2 -5 1/2" drivers, the specs says the 3 1/2" center and sats go to 90HZ but i dont know if i believe that...
thanks for the replies and help....
i kinda double posted this in another thread.... but need advice...
post #15 of 15
So did you got the Dayton? Tomorrow i will get the jamo 426, but i am not sure what sub should i get, the specs of the 1200 look great for the price.
