Hi All,
I am new at this.
I am installing a pair of JBL procinema speakers similar to JBL 4675C. I have the same cabinet 4058A, I have the same JBL 2226H woofers (two for each cabinet). I have 2360A horn. But will be driven by TAD 4002 compresion drivers in stead of JBL 2446.
I will use the system in a room has dimensions of 18' (13' speakers placement due to walk pad) x 29' X 8' ceiling. I will use the speakers mostly for hifi and home theaters applications. The top HF will be powered by tube monoblocks, the bass will be powered with solid state power amps. I am planing to use DBX 260 active x-over. My questions are:
1) Will the combo work?
2) What are the active cross over parameters that you have for the JBL 4675C? Can you share the information with me?
3) what are the minimum amp powers that we would need for this cabinet?
I am new at this.
But I'm sure these are a real upgrade but how much so? I guess I'd have to compare. Lol and no, I won't downsize the woofer section but I will put these high-end diaphragms on my upgrade list.
